Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Needing help - certain plants melting, others not growing
  1. #1
    It has been a long time since I have been here, or really activily trying to maintain a tank. I recently decided to get back into (end of summer). Things were going well, then my light broke, I got a new T5HO fixture and things were looking even better than they had been. Until now. Over the past few weeks the certain plants have been going from bad.. to worse.. to non existent. The following plants are doing very well; riccia, ludwiga repens, blyxa japonica, (a crypt, anubius and java fern - but those really can almost not be killed for me for some reason). The star grass is marginal.. it's not really growing like it was, but is slowly growing and not dying. The ludwiga arcuata is pretty much stalled and seems to be stunted - the top are very small as before it was growing quite large and full. The biggest problem of all of them was the E. Stellata. I have 6-10 stems growing well and now, nothing. Everything melted slowly and I am down to 2 top of stem I am desparately trying to save.
    ph is at 6.6-6.4, kh is around 3 or so. Drop checker reads a slightly greenish yellow (def. more yellow than green) - this has a homemade 4dkh (might be off?) fluid in it.
    I dose EI at 1/4tsp KNO3, 1/8tsp KH2PO4, 1/8tsp K2SO4 (just started that this week) and 1/8tsp of Plantex - all 3x a week on opposite days.
    50% water change weekly (generally speaking).
    2x 39w T5HO lights on 10 hours a day.
    As I said, most things are growing well, but the ones I REALLY want to be in there aren't. I some thread algae, but not even close to bad (this is also new in the last little while - sort of similar time line to the other problems).
    Do the problems in these plants in particular and the algae point to something in particular deficient or excessive? I am at a loss and being in Canada I don't really want to lose any more plants as they are not terribly easy to obtain. I cannot really pinpoint when it started going bad.. I seem to recall adding some seachem equilibrium a couple of weeks in a row and that is when I _think_ it took a turn for the worse. That was a month ago though and I have not added it since. I wonder if it could be that or perhaps a the filter needs cleaning (1.5 months since I cleaned it last)?
  2. #2
    What is your GH, KH? IME, Stargrass (H. zosterifolia) likes adequate Ca and Mg.
    Used to think it (Stargrass) likes low GH by info from some website.
    So I kept low GH and found I had to dose very high Fe to keep it barely survived.
    And it always annoyed me with frequent melting.
    After finding that its natural habitat has quite hard water (both KH and GH),
    I add more Ca and Mg. It becomes stronger. I don't have to dosed very much Fe now.
    http://www.aquamazon.com.br/index.ph...86&layout=blog
    PS: Seachem Equilibrium should have helped. But you suspect it made things worse.
    Well, I've no idea about this. And you might be right. This is a normal issue in this hobby
    (or any hobby related to biology). I should have stuck with electronic toys :P
  3. #3
    Join Date
    Jul 2009
    Location
    The Netherlands
    Posts
    2,214
    I always say P. stellata is a CO2 indicator plant. A deficiency results in stunting and disintegrating crowns. Blyxa etc. are real weeds that will also respond with less growth, but it won't show that much. My advice is to review the CO2 and flow. Don't stare to much at Ph numbers. Your plants are the best test you can have.
    regards,
    dutchy.
    My 2011, 2012 and 2013 AGA entries:
    http://www.barrreport.com/album.php?u=21013
  4. #4
    Hi vinlo,
    You provided the fixture and EI dosing level but you did not indicate the aquarium volume to help make that information relevant. If the new fixture resulted in a substantial increase in light wattage or intensity, then your nutrients (fertilizer and carbon) needed to be increased as well to maintain balance.
    Assuming your drop checker indicator solution is correct you probably have about 30 ppm CO2 which should be fine. Are you dosing the same EI quantities as with the old fixture? Is your photoperiod the same? Are you keeping up with the 50% weekly water changes?
    When Tom Barr visited us at GSAS about a year and a half ago he did an excellent presentation on "The Light Limited Aquarium". There is a thread on the subject on this forum. Two points he made have helped me improve my planted aquarium skills; the first was that I was probably providing too much light (intensity/duration), and the second was reminding me of the importance of maintaining a balance of nutrients and light.
    If it were me, I would start with two 50% water changes over the next week 'reset' the tank. Then I would determine what I changed, or didn't change, compared to when my aquarium was doing well. If you could provide the missing information it might help us provide a better response.
    Roy
    45 Gallon Tall; 96 Watt AH Supply CF; 6700K; & 30 Gallon Long; 2X36 Watt AH Supply CF; Pressurized CO2; UGF; Heat Treated Montmorillonite Clay
    Greater Seattle Aquarium Society
  5. #5
    I had a thought it might be CO2 (as well as Ca/Mg - that is why I had added the Equilibrium). I am using an Up Aqua CO2 atomizer running at about 40psi and 2 BPS. Drop checker reads yellow (as stated earlier that could be a problem with the fluid though). Seems no matter how much I increase my BPS the CO2 seems to stay where it is, perhaps I need a different diffuser/atomizer?
    Also, the crowns of the plant are the only part that is healthy.. the melt starts at the base and works it's way up the stem.
  6. #6
    30 gallon, 36x12x18 or so. T5HO, 2x39w on for 10 hours a day. 50% water change weekly (generally speaking - do miss a week here and there). I have been waffling on the EI quantities. I originally was dosing 3/8tsp KNO3, 1/8tspKh2Po4 and 1/8tsp of plantex all 3x a week. I change that to 1/4, 1/16 and 1/16 - as I reread the newer EI dosing posts. And now do somewhere in the middle of the two. Should I increase the amount?
    I do not have a gH or kH tester, sorry. No one in my city carries them either.
    **edit**
    The timeline is as follows.. got the the light at the end of october, things were great all november and all december - super growth - remembered why I like the hobby. Added the Equilibrium in the begining of January for about 1 month and changed the direction of my outflow. Everythign has gone down hill from there. _Everything_ was doing bad for a while there. Riccia stopped growing, lost most of my Pogostamon helferi, Ludwiga repens got all crazy and started getting holes in old growth and star grass stopped growing. Now all those things are doing alright with the exception of the stargrass but the Limophillia Aromatica (sorry thought it was E. Stellata) and the Ludwiga brevipes (another mistake, darn) are doing poorly.. I also lost a small stand of Baby Tears (completely gone).
    **end edit**
    For a month or two after the light fixture things were going perfect and I remembered what about planted tanks I enjoyed. Since then there are only 2 things I can contribute to the change - 1. I started adding 1/4tsp of Equilibrium and 2. I repointed the filter output to be into the tank more than more toward the top. I have since changed the outflow back and stopped the Equilibrium.
  7. #7
    Join Date
    Jul 2009
    Location
    The Netherlands
    Posts
    2,214
    Quote Originally Posted by vinlo View Post
    ..... the melt starts at the base and works it's way up the stem.
    Still CO2, just with the difference that's it a BIG deficiency. I recently lost all the background plants in my tank because of that. Staring too much at a pH number was the mistake. Now I don't care what the pH says, and my tank is back to where it was again.
    I'd change the drop checker fluid and keep changing it every month.
    I'm not sure about atomizers. The fact that you SEE the CO2 doesn't necessarily mean there's enough.
    regards,
    dutchy.
  8. #8
    Certainly makes sense what you say. But why the sudden change with the CO2? I didn't change the setup since the summer time - same tank (yes there is CO2 in it), same atomizer, bubble rate has gone up and down due to me thinking there isn't enough CO2. Certainly the fish aren't gasping for air at the top or anything so it can be upped..
  9. #9
    Join Date
    Jul 2009
    Location
    The Netherlands
    Posts
    2,214
    CO2 is a gas so hard to grasp what changes. Less flow because of a dirty filter, dirty atomizer, low gas pressure, addition of wood, change in tap water, you name it. You have to stay on top of it. As soon as we take it for granted, it bites you in the butt.
    Light and ferts are very stable, CO2 isn't at all. A lot of factors can influence it.
    regards,
    dutchy.
  10. #10
    P stellata grows extremely fast in my tanks, I put it the back where it is more light limited. My Ca/Mg is lower than yours almost certainly.
    My GH is roughly 2 degrees and often lower, I've never once seen any issues with Ca deficiency over a wide range of tap water and growing conditions having lived many places.
    I've grown this plant maybe 15 years now.
    Even the client's do well with it.
    Light/ferts are fine..this just leaves something to do with CO2.
Similar Threads
  1. Plants sclorosis and melting
    By Rob Rosa in forum Are you new to aquatic plants? Start here
    Last Post: 02-23-2012, 12:37 AM
  2. excel vs melting plants (witch one?)
    By pelmato in forum General Plant Topics
    Last Post: 10-24-2008, 07:20 PM
  3. plants melting
    By torpedobarb in forum General Plant Topics
    Last Post: 06-27-2008, 05:46 AM
  4. plants melting
    By hani in forum General Plant Topics
    Last Post: 10-07-2007, 02:57 PM
  5. Help with melting plants (pics)
    By twilothunder in forum Advanced Strategies and Fertilization
    Last Post: 02-12-2006, 07:26 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
