Fertilizers like Seachem did not last any long in the water column and using any test kits is really senseless there.
You always need to dose such fertilizers
"like the plants look". If you are not sure in doing so - you should perhaps simply better switch back to any stronger chelated stuff (like Tropica Pflanzennahrung flüssig, Drak Ferrdrakon, AR Macro Basic or so).
But you may keep in mind: "Hamburger Mattenfilter"
Generally, such filters "eat" a lot trace nutritions and this is not a "good effekt" in any tanks with plant focus.
And yes, you can try to feed Echi+Crypo with some additional root fertilizer stuff like Terrdrakon or whatever so.
Certainly too much surface agitation is not a very smart thing if it will quickly gas out Co2.
Green Spot algae is primary related a PO4/Co2 issue, you need to fix this.
Clado: You can only kill it with H202 Spotthreatments.
Other things will not really work.
There is really no sense in trying and buying any other plants - because doing so did not fix anything.
Nearly all water plants are at last easy to grow.
But you need to fix (many) things:
- Fertilizer/trace dosing
- Water temp (28 °C = not all plants like such high temps)
- MattenFilter (obvisiously replace it)
- optimize (!) yours waterflow
- optimize Co2
- optimize Substrate
- getting ridd the algaes
This is a much to-do- list.
