Page 24 of 27 FirstFirst ... 142223242526 ... LastLast
Results 231 to 240 of 261
Thread: Starting new tank - codename Frankenstein - critique wanted
  1. #231
    Join Date
    Aug 2011
    Location
    Bucharest, Romania
    Posts
    15
    I guess it's my duty to.. let the pictures do their job.
    It looks like there is a ceramic catalyst, a very cheap thing, which gets the oxygen out of the solution of hydrogen peroxide. You may request a link or two on private. I am not selling the product. I am glad you did restart your thread somehow though. And that it was all because of the way you linked the things up.
    Last edited by client; 07-05-2012 at 11:58 PM. Reason: Watermarked pictures removed; I believe the main participants of this thread have already figured out how is working.
  2. #232
    Join Date
    Jun 2009
    Location
    Posts
    3,205
    Blog Entries
    12
    Smile 6-ppm H2O2 A Couple Times A Day... Desperate Times, Desperate Measures
    Given the calculated (my calculation) level of organic material start at 25-ml twice a day and perhaps if anything work up from there. 25-ml of 3% H2O2 should be about 6-ppm, which I will grant you is quite a bit and H2O2 is harsher than PP, but it is also quicker (1-step), cheaper and will not pull the DO levels. Use a baster or injection device of some kind and inject the H2O2 low (deep) and directly on or around any undesirable looking stuff.
    This is rather a desperation attempt to oxidize organic material and boost the biological filtration.
    I have been running my own tank approximating your organic levels and it appears that you may even be able to double or triple the H2O2; though do not get too carried away just yet.
    Yes, I think the activated charcoal pad is good. For that matter, that super-duper powdered charcoal might be a good idea.
    A bit about my simulations of your tanks, I have been running them for some time now and am even more convinced there is something in the water or somehow added.
    The closest I seem to come to sustained high DOC conditions either is adding continually greater amounts of organic material or add Copper sulfate at sufficient rates to suppress but not kill the biological filtration.
    So far, my filters, simple sumps, mechanical filtration and water spread by tea towels. Biological filtration using stainless steel dish scrubbers and recently (last 3-months) a variety of ceramic media I have been asked to evaluate. Into either, a bucket with some rock and a return pump or 5 or 10-gallon tanks with rock and a baffle or two for true sophistication. These seem to ramp up quite quickly to handle excess loads.
    I have become adept at producing precise amounts of copper sulfate that suppresses biological filtration and does not kill shrimp or snails, but does retard or stop breeding and substantially reduces rotifer populations (principally by reduction in breeding, I think).
    I think we pretty well eliminated copper as the culprit, but my understanding is that metal toxicities are rather similar. I have collected a good kit for screening for metals that I will bring with me.
    I have read something about Client’s device, seems to me it uses a catalyst (since I see “Katalysator,” probably a good guess) to control the release of, or produce the H2O2. I will do a little reading…
    Just saw Clients further post, I will comment later...
    • When in doubt "don't."
  3. #233
    Join Date
    Mar 2011
    Location
    Bucharest, Romania
    Posts
    419
    H2O2 treatment started.
    Premium ROX 0.8 Aquarium Carbon bag inserted in an awkward position under the sump's own sponge.
    One of the new nerite snails is now missing a patch from the shell - this symptom is also similar with my old tank. Except that this snail never had algae attached. Do people actually grow snails at this pH?
    Florin
    Edit: about one hour or so after posting the above, the pH grew about 0.15 and stayed there until now (three hours later).
    Nothing is simple.
  4. #234
    Join Date
    Jun 2009
    Location
    Posts
    3,205
    Blog Entries
    12
    Smile Battle For Buffering, Need To Try For pH 6.6
    Hi Florin,
    I keep snails routinely in the pH 6’s, granted snails prefer alkaline waters but as long as good amounts of Calcium are available, I have not seen a problem. My experience has been snails do not care for higher redox (ORP) values.
    My guess is the main reason the algae on the shell has not happened is your aggressive approach is keeping the algae at bay, combined with your imposing a ban on Vodka consumption.
    The rate of consumption of bicarbonates (all of your alkalinity is bicarbonate) indicates rapid acidification, essentially your tank is and has been for some time, “crashing.” All of the PP and water changes just mitigating the collapse.
    The bacteria in the filters are capable of “operating” down into the low pH 5’s. Though as with many critters, the sudden changes can harm them and this can add to the cascade.
    The H2O2 may be able to oxidize enough organic material that the bacteria can catch up, but until we find the source, it really just continues to be an ongoing attempt to avoid the crash.
    Among the reasons for adding baking soda is to increase and hopefully stabilize pH as pH slips below 6.5 or so the bacteria we depend on start having a tougher time, remember if biological filtration were our main goal we would work to stabilize your pH in the 7.5-7.8 range. Maintaining pH in the mid-6 range is a tradeoff for efficiency of filtration and keeping ammonia as NH4- to protect the critters and allow the plants to help with control. Our preference is to use CO2 to maintain a stable under pH 7, pH 6.4-6.7 seems a good range.
    It may be necessary to reduce CO2 to maintain pH in the mid 6’s if you cannot accomplish this through the use of baking soda. The reduction in CO2 however will probably add to the problem in that the plants will be consuming fewer nutrients.
    In your case, something like 3.6-grams of baking soda should raise your pH 0.4. You need to be mindful of swings greater than pH 0.3 or so in 12-hour period can be hard on the critters. Given that bicarbonates are being consumed is the reason for the more aggressive dosing recommendations.
    The high consumption of bicarbonate (buffering agent) is an indication of rotting material; biological processes tend to lower pH. In most cases, this is the result of a fairly large critter dying unseen, plants suddenly melting, rot in wood something of that sort, occasionally the die-off of a filter or population of worms, rotifers, daphnia or such.
    I remain baffled and befuddled.
  5. #235
    Join Date
    Mar 2011
    Location
    Bucharest, Romania
    Posts
    419
    Hi Bio, thanks for the explanation.
    Was it not for that pesky +0.15 pH induced by the AC and/or the H2O2, I would proudly report a pH of exactly 6.6. Here are today's values:
    t=26.5°C
    KH=55 ppm=3.1 dKH
    GH=144 ppm=8.1 dGH
    pH=6.75
    CO2=29 ppm
    TDS=327 ppm
    ORP=202 mV
    DO=7.58 ppm
    NH3/4=0.11 ppm
    NO2=0.022 ppm
    NO3=3.9 ppm
    After taking the measurements I left the DO and ORP probes in the tank and added tonight's H2O2 dose. Both values climbed slowly and in half hour or so stabilized around
    ORP=270 mV
    DO=7.99 ppm
    Florin
    Nothing is simple.
  6. #236
    Join Date
    Jun 2009
    Location
    Posts
    3,205
    Blog Entries
    12
    Smile Encouraging!
    Hi Florin,
    That is encouraging; the rise in pH after the addition of activated charcoal is a positive indication.
    It would have been interesting to have an alkalinity titration to pH 4.5 before and after the addition of activated charcoal, to see the corresponding rise of 7-ppm bicarbonate.
    The rise in pH I believe is attributable to the sequestration of organic material.
    I think it is safe to try 25-ml of 3% H2O2 three times a day, as close to 8-hours apart as you can.
  7. #237
    Join Date
    Mar 2011
    Location
    Bucharest, Romania
    Posts
    419
    Quote Originally Posted by Biollante View Post
    Mission acknowledged Sir!
    Nothing is simple.
  8. #238
    Join Date
    Jun 2009
    Location
    Posts
    3,205
    Blog Entries
    12
    Smile Excellent Attitude… Now If You Would Help Get Tug’s Mind Right...
    Hi Florin,
    If you would refresh my memory on how you are testing KH.
  9. #239
    Join Date
    Mar 2011
    Location
    Bucharest, Romania
    Posts
    419
    Hi Bio,
    I have the LaMotte 4491-DR Alkalinity Test Kit.
    Florin
    Nothing is simple.
  10. #240
    Join Date
    Jun 2009
    Location
    Posts
    3,205
    Blog Entries
    12
    Smile It Is a Conspiracy, a Conspiracy, I Tell You: CaCO3 for GH & KH
    Hi Florin,
    Thanks, I think I knew that used LaMotte and probably could have looked it up.
    I am thinking, which is painful...
Similar Threads
  1. Critique wanted
    By KnH in forum Are you new to aquatic plants? Start here
    Last Post: 04-27-2011, 03:51 AM
  2. Just starting out! 15G Marine planted tank
    By Alunai in forum Are you new to aquatic plants? Start here
    Last Post: 04-07-2011, 05:02 AM
  3. Starting to plan my next tank - 75 gallons
    By Tamelesstgr in forum Are you new to aquatic plants? Start here
    Last Post: 01-18-2011, 08:56 PM
  4. First Tank-Setup Help/Critique
    By UDGags in forum Are you new to aquatic plants? Start here
    Last Post: 09-15-2009, 03:52 AM
  5. Starting a NON CO2 tank
    By Amitava Chakraborty in forum Advanced Strategies and Fertilization
    Last Post: 02-21-2006, 06:07 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
