Results 1 to 9 of 9
Thread: Help! MP-10 is chopping my shrimp!
    Mar 2010
    Grand Forks, ND
    821
    Unhappy Help! MP-10 is chopping my shrimp!
    The last two mornings I have woke to find 1 or 2 shrimp dead, some with large wounds, one cut in half, below the current of the MP10. They are not directly below, but in the path of the current. I suspect that at night they find themselves swimming into the pump unknowingly where they soon get a serious beat down by the propeller. 6 shrimp in 3 days...no signs of illness or other possible causes. It has to be the pump.
    Would it be bad to shut this down at night? Would plant health suffer from a reduced flow through the lights off period.
    the other thing I'm worried about is shrimp or fish finding their way in when it isn't running and getting the same propeller karate chop when it starts up.
    other suggestions?
    I like using the pump, I see a good flow through the entire tank and would like to continue its use.
    Use the sponge prefilter they supply with the unit.
    Jun 2009
    Surprise, AZ
    3,210
    Blog Entries
    12
    Smile Curiosity Killed the Shrimp
    Hi Shawn,
    You are right the problem with shutting it down at night is they will just get in the other side and be chopped or beaten when you turn it on.
    As Tom Barr mentioned, use the filter.
    Or create an exclusion zone, it will not look nice but using a "breeder" net can solve the problem.
    The first sign we don't know what we are doing is an obsession with numbers. - Johann Wolfgang von Goethe
    Disclaimer: I am not trying to make you mad, it is just what I am, an evil plant monster, 'nuf said.
    • I believe the information I am giving is sound, I am not a veterinarian, professional chemist or particularly bright and certainly not a "Guru.".
    • I assume you are of legal age, competent and it is legal for you to acquire, possess and use any materials or perform any action in your in your jurisdiction.
    • When in doubt "don't."
    Mar 2010
    Grand Forks, ND
    821
    I didn't know they supplied a sponge. I didn't get one. Looks like I will order one.
  5. #5
    Quote Originally Posted by ShadowMac View Post
    That's what I figured...........they should send them with any pump. Ask and complain, they should send it free, or buy 3 pack and have some extras on hand.
    Jan 2012
    Vancouver Canada
    12
    If its suppled phone them and let them know you didn't receive one. Often times they will honour your purchases missing pieces.
    aka outcast - tpt ; neven - bca
    Mar 2010
    Grand Forks, ND
    821
    Thanks, I will give a call.
  8. If you need one quick fluval carries some at petco/petsmart that fit most.
  9. #9
    Jun 2012
    Woodstock, Ontario, Canada
    90
    Is this particular to the Vortech powerheads, or could I expect a similar problem with a Koralia nano? From the pictures I've seen, the Koralia powerheads seem to have a narrow "grille" around the propeller, except for the hole in the front and I don't see any shrimp being able to get in there while it's on.
    Any thoughts?
    Best Regards,
    David
    It takes generosity to discover the whole through others. If you realize you are only a violin, you can open yourself up to the world by playing your role in the concert.
    -Jacques Yves Cousteau
  1. Replies: 15
    Last Post: 09-29-2010, 03:51 PM
  2. co2 and shrimp
    By slowhand35 in forum CO2 Enrichment
    Last Post: 06-03-2010, 08:19 PM
  3. Replies: 10
    Last Post: 04-05-2010, 03:00 PM
  4. Shrimp ID
    By Patrice in forum Inverts
    Last Post: 04-23-2007, 09:37 PM
  5. No3 and shrimp
    Last Post: 10-27-2006, 05:29 PM
