+ Reply to Thread
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Micro Fertilizer DIY Formula
  1. Micro Fertilizer DIY Formula
    I am thinking to create a DIY version of a micro fertz.
    Is it possible to mix the below dry solution to create the DIY version of micro fertz.
    - B ==> from H3BO3
    - Cu ==> from CuSO4
    - Mn ==> from MnSO4
    - Mo ==> from H2MoO4
    - Zn ==> from ZnSO4
    etc
    can i mix all the dry solutions into one Micro fertz solution?
    it would be very wonderful if someone could share the formula
    thanks
  2. #2
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile I Think I Can, Just Not Sure I can Avoid Old Gasbaggism.
    I will give the smart folk a little more time; they probably know a better way.
    Do mind sharing where you are?
    Can you get a chelating agent such as EDTA or DTPA?
    Then if I can think of way without being an old gasbag to explain it, I will try.
    • When in doubt "don't."
  3. Hi
    For the sake of equal distribution of knowledge, I believe being a gasbag is a wonderful thing
    I live in Bali, Indonesia.
    I can get EDTA chelator here fortunately.
    It is quite challenging to get Micro fertz here in Indonesia with EI spec.
    There I would like to create my own DIY version
    I think by mixing all those chemical can be a one good micro fertz
    Hans
  4. #4
    Hans,
    Sending a shipment from the Netherlands to Indonesia costs about €17,50 (or about 22$). I have CSM+B by the kilograms, as well as KNO3, KH2PO4, K2SO4, MG7.SO4, CaNO3 etc. Let me know if you want to buy some from me, i would be happy to ship it to you, however the risk that they find the powders suspicious is yours
    Gilles
  5. #5
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile Some Fake CSM+B
    Hi Hans,
    I am pleased you take my gasbag ways as they are intended, to be informational.
    Having EDTA available makes it easier but chelators abound.
    I have made micro fertz in the past… I never really tried putting them together like this it is rather interesting.
    I am doing a bit of calculating and making sure, I can do whatever I say you should.
    Do you have iron? Actually, iron is one of the easier ones to fake if necessary. Governments have yet to figure out how to ban rust.
    I am assuming Epsom salts are available.
  6. Quote Originally Posted by Gilles View Post
    Hans,
    Gilles
    Hi Gilles
    Importing CSM+B from you is one of the best options available, please let me discuss it with my folks here to have cheaper shipping cost (i hope )
    I realize Bali has been pretty tight about chemical products since the bali bombing a few years ago...
    However, if they do suspect me, i would ask them to taste a little bit to make sure (please make sure you put something fishy in the solution )
    I'll get to you with the result gill.
    Dank je wel
    Hans
    Quote Originally Posted by Biollante View Post
    Hi Hans,
    Hi Biollante
    Fortunately, I have access to get the iron though it is Fe-EDDHA.
    I am planning to ask my friend if they have Fe-EDTA, otherwise I have to mix them myself.
    So, is it okay if I mix H3BO3 to get B, ZnSO4 to get Zn, etc?
    Once it is okay, I will go to the next step...Calculation...
    Thank you for your information
    Hans
  7. #7
    H3BO3 is also the stuff i use to enrich the CSM i get from America to make CSM+B
  8. #8
    I'm in Thailand. Importing chemical fertilizers requires paper here.
    Not for fear of making explosive (except urea, of course),
    but mainly for protecting farmers from low quality, not up to standard ferts.
    Although I think I've been hearing complaints of counterfeit ferts,
    even with that regulation from time to time.
    So I've been mixing my own traces mix by finding the traces mix product
    with lowest Cu ratio and build from there. The lowest I could find has higer
    Cu ratio than the CSM+B. So I diluted it and complemented it with other stuffs:
    Fe-DTPA 7%, Mn-EDTA 13%, Epsom Salt, ZnSO4.7H2O, H3BO3,
    and (NH4)6Mo7O24·4H2O.
    Well, I believe if you could access to Fe-EDTA or Fe-DTPA. You're sorted then.
    Because it's the only one that really needs to be chelated. If I remember it right,
    the only chelated stuff in pfertz's traces is Fe, other ones aren't.
    Since you're not going to build your traces mix from an existing traces mix product.
    The mixing formula depends on how often you want to dose (7x a week or 3x a week).
    And the percentage of your chelated Fe. And what level of each element you're aiming for.
    (I'm mimicing CSM+B).
    To reach the equivalent amount of nutrients from CSM+B, the whole mass of
    my traces mix is considerably heavier than CSM+B. It is mainly from chelating agents.
    I start to think chelating agent may add to DOM (dissolved organic matter)
    and becomes bio-load. So if you can get CSM+B from aboard, that would be
    the best way.
  9. #9
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile A CSM+B Knock-off
    Hi Hans, All,
    I was trying to do something fancy, but it got too involved.
    A do-it-yourself version of CSM+B, none of the measurements are terribly critical, the Copper and Boron are the most dangerous. The EDTA serves as both a chelating agent and filler, making up 59.9% of the product (64% of CSM+B).
    I have not used this myself and am just beginning tests, so obviously use at your own risk. I have done this with a couple of variations, I will get into one later, specific to Hans’ situation.
    Since I started with the ingredients Hans has available that are what I used. Since the hydrates were not specified, I went with the most common hydrates.
    For those concerned with sulfate, this recipe contains 10.2% sulfates, and given the quantities added to the aquarium, I seriously doubt any adverse effect. Of course, it is also providing 6.86% plant-friendly Sulfur.
    Thorough mixing is the main “trick,” all full of good intentions I started with mortar and pestle and ended with TheLoudCreatureWhatSharesMySpace’s spice grinder…
    This recipe results in one kilogram of product and allows for weighing in 1-gram increments a scale that reads to 0.1-gram is sufficient, as long as care is taken with the Copper and Boron, there really is not any great danger. Obviously, the recipe can be scaled (up or) down.
    I found in a couple of runs that grinding, mixing and homogenizing the iron, Manganese, Copper and Zinc with the EDTA first, then adding the other ingredients seemed to work best.
    Generic form,
    EDTA, Ethylenediaminetetraacetic acid-------------------------------------------599-grams
    MgSO4●7H2O, Magnesium sulfate hepta-hydrate, Epsom salt, ------------152-grams
    Fe2O3●3 H2O, Iron (III) oxide tri-hydrate, Rust-----------------------------------132-grams
    MnSO4●5 H2O, Manganese sulfate penta-hydrate ----------------------------- 89-grams
    ZnSO4●7 H2O, Zinc sulfate hepta-hydrate----------------------------------------- 18-grams
    H3BO3, Boric acid-------------------------------------------------------------------------- 5-grams
    CuSO4●5H2O, Copper sulfate penta-hydrate (blue)------------------------------ 4-grams
    H2MoO4, Molybdic acid or dihydroxidodioxidomolybdenum------------------ 1-gram
    59.9% EDTA
    10.2% sulfate (3.4% Sulfur)
    7% Iron (chelated)
    2%Mangenese
    1.5% Magnesium
    .87% Boron
    .41% Zinc
    .1% Copper
    .06% Molybdenum
    A couple of comments and substitutions later…
  10. #10
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile Iron Sulfate
    In real life Iron sulfate is easier to come by at the local garden shop.
    Iron sulfate is usually available as the hepta-hydrate, FeSO4●7 H2O, it will appear green(ish). Heat it to 90⁰ C and it will eventually turn white(ish) to colorless and becoming the monohydrate.
    Iron (II) sulfate hepta-hydrate version, a lot less EDTA.
    EDTA, Ethylenediaminetetraacetic acid-------------------------------------------382-grams
    FeSO4●7 H2O, Iron (II) sulfate hepta-hydrate, ---------------------------------------349-grams
    38.2% EDTA
    22.3% sulfate (7.4% Sulfur)
    7% Iron (chelated)
    2%Mangenese
    1.5% Magnesium
    .87% Boron
    .41% Zinc
    .1% Copper
    .06% Molybdenum
+ Reply to Thread
Similar Threads
  1. Help verifying a PP dip formula
    By pat w in forum General Plant Topics
    Last Post: 08-13-2010, 05:48 AM
  2. RCS and APN micro mix
    By cazandchris in forum Inverts
    Last Post: 06-16-2010, 02:30 AM
  3. plant biomass formula
    By crystalview in forum Are you new to aquatic plants? Start here
    Last Post: 09-08-2008, 05:04 AM
  4. Simple formula to calculate maximum error term for EI
    By orion2001 in forum Estimative Index
    Last Post: 04-01-2008, 04:06 PM
  5. Barr's GH Booster Formula?
    By greenfish in forum CO2 Enrichment
    Last Post: 09-02-2007, 01:01 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
