+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: CSM+B, how much?
  1. #1
    Join Date
    Nov 2010
    Location
    Antwerp, Belgium
    Posts
    310
    CSM+B, how much?
    Hi guys
    I've just made my own solution of CSM+B. I added 100 gram to 1000ml of water. How much should I add for my planted 100l (26g) using the Estimative Index?
    Here's the contents according to the manufacturer's site (50gr/500ml):
    Element micromol/L ppm (mg/L)
    B 27,70 0,30
    Cu 0,79 0,05
    Fe 33,30 1,86
    Mn 8,74 0,48
    Mo 0,52 0,05
    Zn 4,30 0,28
    It also contains Fe, does that mean I no longer have to add Fe separately? I'm pretty new to this since I've always been using Profito for my trace elements.
    Thanks!
    Gilles
  2. #2
    Join Date
    Jul 2009
    Location
    The Netherlands
    Posts
    1,359
    I have the same one and use 10 ml per 100 liters of water, dosing 1x per week. Mind that profito also contains K+, Ca and Mg. I don't add additional Fe.
    regards,
    dutchy.
    My 2011 AGA entry:
    http://showcase.aquatic-gardeners.org/2011/show29.html
  3. #3
    Join Date
    Nov 2009
    Location
    Daphne, AL (east Mobile Bay)
    Posts
    462
    Blog Entries
    Just FYI. That dose of CSM+B solution adds right at 0.65ppm Fe into 100L.
  4. #4
    Join Date
    Nov 2010
    Location
    Antwerp, Belgium
    Posts
    310
    Quote Originally Posted by dutchy View Post
    So Profito is more "complete"?
  5. #5
    Join Date
    Jul 2009
    Location
    The Netherlands
    Posts
    1,359
    Yep. I don't use it because there's enough K+ through the KNO3 and there's enough Ca and Mg in the tapwater here. Just a matter of economics basically.
    regards,
    dutchy.
    My 2011 AGA entry:
  6. #6
    Join Date
    Nov 2010
    Location
    Antwerp, Belgium
    Posts
    310
    Dutchy, apparently I was looking at the wrong product. This is the one I mixed:
    http://www.aquariumbemesting.nl/beme...envoeding.html
    Basically it's CSM+B with extra magnesium and K+
  7. #7
    According to wets calculator :
    Your dose of 100.0 g Plantex CSM+B into your 1000.0 mL container, with doses of 10.0 mL into a 26.0gal tank gives:
    Element ppm/degrees
    B 0.12
    Cu 0.01
    Fe 0.66
    Mg 0.14
    Mn 0.19
    Mo 0.01
    Zn 0.04
    dGH 0.03
    If you are doing EI Method the EI target ranges are:
    CO2 range 25-35 ppm
    NO3 range 10-30 ppm
    K+ range 10-30 ppm
    PO4 range 1.0-2.0 ppm
    Fe .2-0.5ppm or higher
    GH range 1-2 degrees "extra" 17-40 ppm or higher
    Here are the links:
    EI method:
    http://www.barrreport.com/showthread...ss-techy-folks
    Wet's calculator:
    http://calc.petalphile.com/mobile
    I dose my 55G tank micro nutrients three times a week...SUN-TUE-THU. However, my dose is different as my solution is 500ml and I dose 60ml 3x a week.
    Fir my macros:I do the same dose as for micros I do this as the solution is meant to last close to three weeks. The faster the solution is used the less chance of getting mold on it. If anyone else can guide me on what I can add to my solution to prevent this from happening I would be very grateful.
    Hope this helps.
  8. #8
    @All; the products referenced are the products i sell; the latter one (complete plant nutrition) is modeled after the recipe on "The Krib" which states to add additional K and Mg to make it complete. The only thing that is missing is "Ca".
  9. #9
    I tend to dose about 0.4ppm of Fe per dosing which is 3-5x a week.
    Pretty rich compared to everyone else.
  10. #10
    Join Date
    Jul 2009
    Location
    The Netherlands
    Posts
    1,359
    Quote Originally Posted by Gilles View Post
    I think you are too low with your prescribed dosage on both.....
    regards,
    dutchy.
    My 2011 AGA entry:
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
