I had previously read that you could just buy a sensor for 139 and a cheap multi-meter and multiply the milivolts by 5 to get the PAR. After speaking the the Apogee tech support guy, he said that yes this combo would do the same thing as the more expensive meter, but that the only drawback is that you couldn't data log. The leveling plate is more for outdoor sun use to make sure you get the proper orientation throughout the range of the sun during the day-it is not necessary, won't fit in the aquarium and you can just attach it to a plastic stick and move it around to measure the highest reading.
I bought the Apogee SQ-120, which is the sensor only (electric calibration):
http://www.apogeeinstruments.com/quantum/index1.html. I bought this Equus auto-ranging meter at Amazon $17:
http://www.amazon.com/gp/product/B000EVYGZA
That and a pair of jumpers to connect the leads and it works fine--Apogee PAR meter for $150.
The Equus meter will auto range to milivolts-just multiply times 5 to get the par.
I also was worried about calibration of the sensor-the Apogee tech support guy said that the sensor will lose about 2% per year when in the sun all day--under electric lights it should never need to be calibrated--especially if used only periodically.
There is a weird bulge in the sensor's cable about 18 inches from the sensor and it is in a rubber shrink wrap. I was worried about submerging that part. The tech support said it was "the in-line electronics and is heat shrinked with adhesive wrap and is ok to submerge".
This set-up seemed clunky and rinky dink until I got familiar with reading the meter-I kept having trouble getting it on the right settings, but once I got the meter setting right (DC volts) and saw the different responses in different places (shade vs. right under the light), I could see that it was working correctly and I was very pleased.
Turns out I had 80 Micromole at substrate only in the very front center substrate and the rest of the substrate was 30-50 Micromoles. At the surface it was 200 Micromoles.
I took pictures, if anyone is interested let me know and I will post (if I can find the camera).
FYI, on the sensor, there are three strands: red, black and a clear wire with silver strands. The Red goes to the Plus on the meter. The Black is the negative and the clear is the ground-twist them together and connect to the Negative on the meter. Turn the meter to DC volts.
I mounted it on the end of an algae scrubber handle with the provided nylon screw.
46 Bowfront
4X39w Tec 5 light 8" inches above tank and 20" from substrate.
