Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 170
Thread: Left C's 40BR Journal
  1. #1
    Join Date
    Sep 2005
    Location
    Burlington, NC
    Posts
    2,510
    Hi
    I just finished assembling the stand for my 40BR and I have two choices that I can use for pressurized CO2 diffusion. One is the 5/8" Up-Aqua Atomizer and the other is an Eheim adjustable speed needle wheel pump. Which would you suggest?
    It will be plumbed inline after an Eheim 2028 Pro II and a Hydro heater. I'll be using the Eheim optional grey plastic intake and spray bar (installation kits). I have a T5HO fixture that I'll only be using the two outside bulbs. One bulb is the Giesemann Midday 6000K and the other is their Aquaflora. I'll be using Amazonia for the substrate.
    Thanks,
    Left C
  2. #2
    Join Date
    Sep 2007
    Location
    Posts
    5,581
    I think the atomizer will work well...I am a bit concerned that it is also after the hydor...
    As long as you can give 25 psi....
    Plus, the UP sticks to the outside glass and is out of the tank. No electricty either...
    What version of ADA?
    Thanks,
    Gerry.
    'When something's not right, it's wrong'. Bob Dylan
    Current 220 scape
    http://www.barrreport.com/showthread...3219-220-video
  3. #3
    Join Date
    Sep 2005
    Location
    Burlington, NC
    Posts
    2,510
    It is the original Amazonia.
    I can give it 25 psi or more. I have several regulators to pick from.
    Edit: Why are you concerned that it is after the Hydor heater?
  4. #4
    Join Date
    Sep 2007
    Location
    Posts
    5,581
    Quote Originally Posted by Left C View Post
    Just in case the eheim is underpowered or the diameter hose to the heater is LESS than the canister. Just want to ensure the atomizer gets enough flow although I admit to having no idea if this is really an issue or not.
    Just the way my mind works to think of these things...
    That was pretty funny. Understatement of the year coming from you LOL
    Did you buy the ada original on purpose to avoid the new type? Or did you have it put aside already? Thanks
    Thanks,
    Gerry.
    Current 220 scape
  5. #5
    Join Date
    Mar 2010
    Location
    Seagoville, TX (near Dallas)
    Posts
    985
    When I was building my sump and everyone was explaining to me about "head" no pun intended. I thought well if everything is inline and your not adding extra tubing that loops around then I should be ok adding things inline. Makes sense to me. From my pump I have a ball valve, riser, quick disconnect, check valve, and my atomizer. It all runs one after the other without losing extra head. There is no slack in my line therefore no loss of flow.
    JJ
    Plants give me peace!
  6. #6
    Join Date
    Sep 2005
    Location
    Burlington, NC
    Posts
    2,510
    Quote Originally Posted by Gerryd View Post
    I understand what you mean. It is OK. The Eheim 2028 uses 16mm or 5/8" ID tubing and everything fits that same size tubing.
    The pump output of 2028 is 277 gph which, just guessing, may be around an actual 200 gph from some of the lists that I've seen as in this canister spec list. The Eheim needle wheel pump has an adjustable rating from 211 gph up to well past what I would need. It could supply the added pull that I may need to get good flow. I could tweak it as needed. I do have a 5/8" UV that I could add, but I haven't decided if I will use it. If I use all this stuff and keep it under the stand, I should end up with some bends and most likely some right angle bends too. This is another reason where the pump may be helpful. It can help to pull this stuff along. I'll have to plum the pump last because we can't have a mist going through the Hydor inline heater or an UV sterilizer, I don't believe.
    When I ordered my Up-Aqua Atomizers, I ordered the 12/16mm and the 16mm/22mm versions. There is one for a 2217 and the other is for a 2028. I can't find the 16/22mm version that I need to go with the 5/8" tubing above. It is here somewhere. I found the 12/16mm version. This is OK because I have an Eheim 2217 that uses 1/2" or 12mm tubing. I have a 12mm Hydor heater too. The Eheim 2217 and 2028 have similar flow rates. I could use either, I suppose. I was planning to use the 2217 with the 37g. I do have an Eheim 2213 waiting if I need some extra circulation.
    It sounds crazy to have all this stuff, but I bought it a piece at a time over a few years. I started getting stuff for a 37g and then I started getting stuff for a 40BR. I have all this stuff before I have either tank set up and going. In this case, I can "rob Peter to pay Paul" so to speak with the filters and accessories since the aquarium volumes are almost the same.
    I need to get something going because my 29g grow out tank is crammed full of plants that I plan on using with these aquariums.
    I feel like "Suitcase Jake" because I have so many.
    I bought the Amazonia before the II version came out and I set it aside for this use. I also have three bags of Black Flourite, but I don't want to use it for this project.
    Below is the "Moss Arch 'Scape" that I was going to put in the 37g. It is just too narrow to do something like this with the large driftwood that I have that makes up the arch. I'm going to put it in the 40BR instead. The aquarium that Amano used for this 'scape is similar in size to a 40BR anyway. This came from the Jan-Mar 2011 issue of The Aquatic Gardener. Below is whole article, but the 'scape that I am trying to copy is on the first two images.
  7. #7
    Join Date
    Sep 2005
    Location
    Burlington, NC
    Posts
    2,510
    Quote Originally Posted by jerrybforl View Post
    Thanks JJ. I'll see if I can run everything in a straight line. If I add a probably un-needed UV, I may have some bends that I don't like. Then this is where some help from the needle wheel pump may come in.
  8. #8
    Join Date
    Sep 2005
    Location
    Burlington, NC
    Posts
    2,510
    I got industrious and worked on the 40BR yesterday evening. I plumbed everything and I assembled a two stage regulator.
    The 40BR has: running inline
    The two stage regulator is/has:
    • a Victor VTS253A-320
    • a Burkert solenoid
    • an Ideal 52-1-12 needle valve
    • a Parker 1psig check valve between the needle valve and the bubble counter
    • a JBJ bubble counter
    • a Clippard inline check valve
    • Tygon lab tubing 1/8" x 1/4"
    I checked my regulator assembly for leaks and I didn't see any.
    I filled the 2028's media trays with the appropriate media and rinsed it. I'll let it dry overnight.
    I'll hook everything up after lunch today and check for leaks. Everything fits inside that "cheap" stand even the CO2 tank. The only bad thing about the stand is that it only has one door, but it is wide enough to allow access to the equipment. I can remove everything rather easily for maintenance, which is very important to me.
    I'm glad that I was rather industrious yesterday. If it doesn't leak, maybe I can plant it by evening. We'll see. I just hope that I don't have to deal with any leaks.
    I went in this direction because I couldn't find the 5/8" Up-Aqua Atomizer. If this doesn't work, I can go with either the 1/2" Up-Aqua Atomizer or rob the AM1000 reactor from the grow out tank.
  9. #9
    Join Date
    Sep 2005
    Location
    Burlington, NC
    Posts
    2,510
    I'll be using Amazonia original. I have some substrate amenities that I am considering placing underneath the Amazonia on start-up. This is what I have:
    • Activated Filter Carbon
    • Leonardite
    • Canadian Sphagnum Peat Moss
    • Osmocote Plus
    • Dolomite
    • Potash
    • Ferrous Sulfate
    • Seachem Flourish Tabs
    • Wonder-Gro Root+ aquarium plant substrate tablets
    Will any of these products help the Amazonia initially?
    Thanks for your help. I don't remember reading about anyone adding anything extra other than some mulm from an established aquarium and maybe some carbon..
  10. #10
    Join Date
    Jun 2009
    Location
    Minnesota, USA
    Posts
    119
    Hi Left C,
    This is very similar to a setup I'm considering. I've never used Canister filters before (still reading up on them), but I'm curious, what is "appropriate media" specifically?
    Thanks!
    Tim
Similar Threads
  1. Replies: 32
    Last Post: 12-17-2013, 03:12 PM
  2. My two SGT500s (thanks to Left C)
    By Matt F. in forum CO2 Enrichment
    Last Post: 05-06-2011, 10:46 PM
  3. Budget build, some suggestions on what's left.
    By lipadj46 in forum CO2 Enrichment
    Last Post: 04-12-2011, 04:33 PM
  4. My First Aquascape Journal
    By Steven in forum Are you new to aquatic plants? Start here
    Last Post: 08-31-2009, 09:39 AM
  5. Planted Atasuki Trophy Journal
    By Myka in forum General Plant Topics
    Last Post: 07-24-2009, 04:50 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
