My tank is 150 gallons. My lighting is at 3W/gallon.
And also I have easy access to K2SO4 So if I am to use K2SO4 and CaNo3, what should be my dosage in terms of tsp? Thanks!
For general, high light in a 150-gallon aquarium dosing three times a week assuming 50% weekly water changes:
1.75 teaspoons --------------- Ca(NO3)2.4H2O
1 teaspoon ------------------- CaCl.2H2O (my favorite) OR (CaSO4)2.H2O (Plaster of Paris)OR 2 teaspoons CaCO3 (agricultural lime OR dried crushed egg shells)1 teaspoon--------------------- K2SO4
1⁄8 teaspoon ----------------- KH2PO4 OR 3 milliliters Fleet Enemas
½ teaspoon ------------------- CSM+B,
2 milliliters ------------------ 0.5% Boron solution (46 grams of Borax in 1 liter solution with distilled water.)
1 teaspoon -------------------- Epsom salts (MgSO4.7H2O)
¼ teaspoon -------------------- 10% Chelated Iron
I hope this helps.
- I believe the information I am giving is sound, I am not a veterinarian, professional chemist or particularly bright and certainly not a "Guru.".
- I assume you are of legal age, competent and it is legal for you to acquire, possess and use any materials or perform any action in your in your jurisdiction.
- When in doubt "don't."
Hi Billante,
Sorry but I am an idiot ahha. So is it
1.75 teaspoon of CaNO34H2O
and 1 tsp of CaCl2H2O
and 1 tsp of K2S04
and 1/8 tsp KH2PO4
So all these for the Micro part??
Hi Billante,
and 1 tsp of K2S04
and 1/8 tsp KH2PO4
So all these for the Micro part?? The OR kinda confused me.
Sorry again just to make sure as they state it in terms of the names and not the Chemistry symbol, so what I need to dose is
1.75 tsp of Calcium Nitrate
+ 1 tsp of Calcium Chloride
+ 1 tsp of Potassium Sulphate
+ 1/8tsp Potassium Phosphate
Three times a week.
Is this correct?
The “OR” indicates a choice, in the English language “or” is a coordinating conjunction introducing an alternative. I struggle with English, as anyone who reads my posts can deduce. “OR” could also be viewed as a logical operator, meaning any of the statements make the condition “true.”
In this case you had not told me what other sources of Calcium you had available so I listed three possibilities. I happen to favor CaCl2.2H2O, because I like the Cl2 part as well (that is somewhat controversial). (CaSO4)2.H2O is available almost everywhere. CaCO3 is available in a number of forms including egg shells, which most folks have access to and foolishly throw away.
These are in the macronutrient group.
The CSM+B, Boron and iron are micronutrients. The Epsom salts tend to get lumped in but I believe, at least technically, Magnesium would be a macronutrient.
The parenthesis, sub and superscripts are important…
Ca(NO3)2.4H2O is called Calcium nitrate tetra-hydrate.
So we have:
- Ca is Calcium
- NO3 is nitrate, which is made up of one Nitrogen molecule and three Oxygen molecules.
- Notice the parenthesis around the nitrates “(NO3) with the subscript “2”
- (NO3)2, this means there are two nitrate.
- The “.” (often represented by an asterisk) indicates an “hydrate.”
- Hydrate indicates that a substance contains water.
- In this case “4H2O” means four water molecules attached we refer to that as “tetra-hydrate.”
Calcium nitrate tetra-hydrate, Ca(NO3)2.4H2O
Calcium chloride di-hydrate, CaCl2.2H2O,this is often available as Calcium chloride hexa-hydrate, CaCl2.6H2O, you will need about 16% more if you use the hexa rather than the di-hydrate. If you order your Calcium nitrate from a chemical supply house you may get anhydrous Calcium chloride CaCl2.Calcium sulfate, CaSO4 is most commonly seen as plaster of Paris, (CaSO4)2.H2O, occasionally you will see it written as CaSO4.1⁄2 H2O
Calcium carbonate, CaCO3
Potassium sulfate, K2SO4
Monopotassium phosphate, also known as potassium dihydrogen phosphate, KDP, or monobasic potassium phosphate, MKP, KH2PO4.Fleet Enema’s 16 g sodium biphosphate and 6 g sodium phosphate per 100 mL solution are a great, precisely measured substitute.I hope this helps someone.
Bookmarks
