+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Can we replace KNo3 with CaNo3??
  1. Can we replace KNo3 with CaNo3??
    Hi Tom and everyone else,
    As KNo3 is now a banned substance where I am (Singapore) can we use CaNo3 instead? So if we do use CaNo3, then
    1. Would the dosage be exactly the same as if we were using KNo3?
    2. Would the Ca add to the hardness of the water?
    Thanks.
  2. #2
    Join Date
    Nov 2010
    Location
    Baltimore, MD
    Posts
    448
    From what I gather online it is Ca(NO3)2. That means for two nitrate ions you get a single calcium. It would make your hardness go up. It is nicely soluble so the plants would get the benefit. It wouldn't contribute to the potassium level so you would want to augment that.
    Jim (neither a chemist or botanist)
  3. #3
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile Clear As Mud... Real #'s Work Best, If You Care To Share
    Yes Ca(NO3)2.4H2O is a good replacement for KNO3.
    To get a similar amount of NO3 use about 15% more Ca(NO3)2.4H2O. For the level of NO3 added you will be adding about 30% of the NO3 amount in Ca.
    To replace the K, add an amount of K2SO4 equal to 30% less than the amount of Ca(NO3)2.4H2O dosed.
    • When in doubt "don't."
  4. #4
    Please excuse me,
    If I dose Ca(NO3)2.4H2O instead of KNO3. Will I get the same benefits of dosing CaSO4 at water changes to boost the GH?
    Thanks,
    Juan
  5. #5
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile Sorta
    Hi Juan,
    Different GH boosters have different mixtures. Barr’s GH Booster is 3:3:1; K2SO4*: CaSO4: MgSO4.7H2O.
    Calcium nitrate,Ca(NO3)2.4H2O is almost 17% Calcium and if you are dosing Potassium sulfate, K2SO4, you are getting the Potassium and the sulfate, so all that is missing is the Epsom salt, MgSO4.7H2O.
    Again real information about your situation makes it easier to help.
    *the packaging I have indicates 3 parts KSO4 while the Planted Aquarium Fertilizer website specifies Potassium sulfate, http://www.aquariumfertilizer.com/in...ditU=2&Regit=7 so I accept the K2SO4 as correct
  6. #6
    Thanks Biollante,
    I was just curious.
    I was looking for some CaSO4 at my local farm products store the other day, but they didn't sell it, they had Ca(NO3)2.4H2O and K2SO4 though.
    I'm already dosing MgSO4.7H2O at water changes, so, I was wondering If could replace the CaSO4 and the KNO3 with Ca(NO3)2.4H2O in the case that I couldn't find any gypsum at the nearby crafts stores.
    Thanks,
    Juan
  7. #7
    Quote Originally Posted by shrimppaste View Post
    Thanks.
    Please check before you buy. There're two types of the so-called Calcium Nitrate.
    The NPK:15.5-0-0 + 19% Ca, is actually 5Ca(NO3)2.NH4NO3.10H2O.
    http://www.dlchem.com/pages/20091117...-nitrate.shtml
    This one contains ammonia.
    The NPK:11.9-0-0 + 16.9% Ca, this one is Ca(NO3)2.4H2O.
    http://www.alibaba.com/product-gs/42..._99_AR_CP.html
    This one contains no ammonia.
  8. Can I use CaNo3 with KH2PO4? And if yes, what should be the dosage as I am currently using KNO3 with KH2PO4. Thanks.
  9. #9
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile Do Not Toss Those Egg Shells
    Quote Originally Posted by chopsticks View Post
    Thanks Biollante,
    I was just curious.
    Thanks,
    Juan
    Hi Juan,
    I apologize I must have misplaced this thread.
    Nipat's point is a good one especially when purchasing as agricultural products, make sure it is Ca(NO3)2.4H2O.
    The Ca(NO3)2.4H2O and K2SO4 make a good combination, you end up light on the Calcium, but not too bad.
    For extra Calcium do not overlook Calcium carbonate CaCO3, agricultural lime.
    • Crushed, dried egg shells, seashells are great sources of CaCO3.
  10. #10
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile More K... OK?
    You will need to find an additional source of Potassium (K+2), the KH2PO4 is a really great source of phosphate,
    and you would end up dosing very high phosphates to have a reasonable level of potassium.
    Something like Potassium phosphate (K2SO4) is a good source.
    If you care to share your tank volume statistics perhaps we can be of more help.
+ Reply to Thread
Similar Threads
  1. Replace old filter
    By vietxtlife in forum Are you new to aquatic plants? Start here
    Last Post: 07-07-2011, 01:31 PM
  2. 2 years old planted tank need to replace substrate?
    By fablau in forum General Plant Topics
    Last Post: 02-19-2011, 09:00 PM
  3. Replace my Limnophila
    By jonny_ftm in forum General Plant Topics
    Last Post: 05-05-2009, 08:48 PM
  4. I have to replace my tank :(
    By kazooless in forum Talk to Tom Barr
    Last Post: 07-12-2007, 08:31 PM
  5. CaNO3
    By PK1 in forum Advanced Strategies and Fertilization
    Last Post: 10-13-2005, 03:47 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
