+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: GH dosing for RO water
  1. #1
    Join Date
    Mar 2010
    Location
    Grand Forks, ND
    Posts
    715
    what is the recommended GH booster dosing at water change for RO water? How much per 5 gallons? I store my RO in 5 gallon jugs and that would be easiest. Otherwise, how much per 20 gallons?
    I am using Barr's GH booster from aquariumfertilizer.com.
  2. #2
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile A Little of This... A Bit of THat... Mix Well.
    Hi Shawn,
    Aerate the RO thoroughly, mix, stir, or shake, whatever, ideally a small air pump and air stone during storage.
    A teaspoon of Barr’s GH booster will give you about 2-dGH and about 10-ppm Potassium.
    I would add another ¼ teaspoon of CaCl2.6H2O for another .6-dGH and I like the Chloride. If no Calcium chloride, ¼ teaspoon plaster of Paris.
    • If you wish a greater general hardness add more plaster of Paris or Calcium chloride, about .6-dGH per quarter teaspoon.
    I would add a light 1/5 teaspoon Baking soda, this will leave about 2-dKH.
    I also like dash of lemon juice, a dash of crushed vitamin C tab works.
    Raising sensitive plants or critters I like to match the water as closely as possible.
    • When in doubt "don't."
  3. #3
    Join Date
    Mar 2010
    Location
    Grand Forks, ND
    Posts
    715
    Thank you!
    what volume of water are those doses for?
    I have an idea for storage, I plan to drill holes in the top of the 5 gallon containers lids, run an airline to the bottom with an airstone. Since they will no longer be water/air tight I will just have to be more careful when moving them.
  4. #4
    Join Date
    Mar 2010
    Location
    Grand Forks, ND
    Posts
    715
    *double post
  5. #5
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Red face Oops...
    Hi Shawn,
    Sorry, I was thinking (really hurts!) in terms of 5-gallon units as per your original post.
  6. #6
    Join Date
    Mar 2010
    Location
    Grand Forks, ND
    Posts
    715
    I would have to say without a doubt I have been under dosing my GH booster. I've been adding 1/2 tsp to 1 tsp per 15 gallons or so of RO.
  7. #7
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile KH Is A Bigger Deal Than GH, In This Case Anyway...
    Hi Shawn,
    I seriously doubt general hardness was a major problem, carbonate hardness is, perhaps another matter.
    I do think consistent water management is important.
    I think I will try that TSS, TDS, organic versus inorganic and what we “see” with a TDS meter…
  8. #8
    Join Date
    Apr 2010
    Location
    Phoenix, Arizona, USA
    Posts
    220
    In AZ, some aquarium keepers just use half tap and half RO.
  9. #9
    Join Date
    Jun 2009
    Location
    Posts
    2,862
    Blog Entries
    12
    Smile Well Mixed Tap & RO/DI Works Wonderfully Well!
    Quote Originally Posted by Crispino Ramos View Post
    Actually the mix of tap, RO and DI water is what I use for the most part.
    I find in keeping certain critters and certain plants when keeping the carbonate hardness under 2-dKH that reconstituting the water from DI is the most effective.
    ps. come to think of it I am in AZ so I was covered by Mr. Ramos' statement...
  10. #10
    Join Date
    Mar 2010
    Location
    Grand Forks, ND
    Posts
    715
    I use RO to prevent fluctuations in water quality. My tap varies especially in the spring. My electric blue rams prefer the RO. Its not necessary for any plants.
    average ph of the tap is 9. it is hard water with a high kh.
    The tank isn't large so RO isn't tough.
    Regarding low GH dosing, could I have been low on calcium or magnesium?
    CO2 was the main reason for growth and algae issues recently.
+ Reply to Thread
Similar Threads
  1. LA Water Parameters and Mg/Ca Dosing
    By SunnyD in forum Aquatic Plant Fertilization
    Last Post: 03-17-2011, 02:52 PM
  2. EI dosing when using RO/DI water
    By BayBoy1205 in forum Aquatic Plant Fertilization
    Last Post: 12-22-2009, 02:13 PM
  3. EI dosing and water changes
    By fjf888 in forum Are you new to aquatic plants? Start here
    Last Post: 01-22-2009, 09:57 PM
  4. EI dosing: do I add dry or mix with water
    By stacir in forum Are you new to aquatic plants? Start here
    Last Post: 04-17-2008, 10:10 PM
  5. Water Column Dosing
    By aquabillpers in forum General Plant Topics
    Last Post: 07-27-2006, 08:53 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
