Question, what salt mix do all of you use? Was leaning towards Red Sea Pro Coral salt as somebody mentioned that the Mag and Calcium levels are good. Would get the big tub.
Was also going to go with Seachem for dosing the chemicals, as its available everywhere in Miami. Just want to confirm that it's Ca++ and Carbonate that I need to dose. No Magnesium, or should I do that too? I figured with the waterchanges, trace is not needed. Nitrates down the road?
One more question, was curious. If I build up a LR scape so that it has some height, tank is 21" deep, doing a 50% waterchange will lower the water level significantly. I know when I do waterchanges that big in Planted tanks, that they plants are fine for a spell while I drain the water. But what about corals and macro-algae? I imagine the Macros may be ok, but the corals might not be. Will ricordea and shrooms be ok, or should I put them below the 50% mark? Or divide the waterchanges into two 25%?
I know weird question. Thanks.
Bookmarks
