Hi there,
I have been doing quite a lot of research and have viewed quite a few threads here and other places as well. I currently have a 90G planted Discus tank with pressurized C02. Everything started well and lasted well for a about 3-4 months, so needless to say I am new to dosing and the EI.
Recently I have noticed the start of several different algae types which makes me believe there are some ferts/variables out of balance. I have used the usual methods of drop checkers and the PH/KH tests that aren't that reliable. The tests however lead me to believe I do have enough C02 in the tank. I should also mention I have 4 T5HO bulbs @ 54w each. 2x 6000K 54 W / 2x 650nm 54 W
I have been reading quite a lot about limiting certain variables in the aquarium. I have tested for P04 (Phosphates) and have consistently tested 0 before I started dosing.
So I received my ferts and have dosed once using the EI method. Specifically I will mention P04 going forward (Yes I have dosed all other ferts as well). After dosing the initial 1/2 tsp of KH2P04 I tested for phosphates and received ~.25 mg/l reading. I have also read that a target range should be between 2-5 mg/l.
I am wondering if I need to dose up to this level initially and then possibly follow the EI guidelines and adjust to keep levels in that target range? Thank you in advance for any information provided. Any other comments or advice is welcomed as well.
Cheers,
Daniel
Bookmarks
