90gal CO2 tank now 4+ months old. About a month ago I was just starting to congratulate myself (or more accurately, thank Tom for his advice that I followed [in some cases against my own judgment]) because I had seen NO ALGAE.
Then some GSA and hair algae started to crop up. I killed VERY large clumps of needle leaf java fern spraying with 100% excel.
I adjusted flow patterns.
I pointed CO2 output directly into plants.
I did H20 changes frequently.
I recycled CO2 by bringing "false gas valve" of AM1000 back to pump intake.
I turned up bubble rate so it is so fast I can no longer count (maybe 8-10+ bps).
I just reduced photoperiod.
I'm hoping you friendly folk will offer me some input. I assume inadequate CO2 is responsible for my GSA, and thread algae.
I'm interested in whether my current design is adequate. On the surface it seems it should be --more than adequate-- for a 90gal tank. But apparently it is not, or I am not tuned in to what to change, and this is my problem.
The attached diagram illustrates my CO2 design. One possibility is to get rid of the AM1000 with tiny 1/2inch I/O and replace with larger reactor (3/4"? I/O). If I do that, same pump OK? I'm kinda lost in what to change.
What options, for my set up, would seem to make sense for enhancing CO2?
thanks for any feedback,
growitnow
90gal
KNO3: 15ppm, 3x
KH2PO4: 6ppm, 3x
K2S04: 17ppm, 3x
Trace (TPN): 25ml, 3x
Iron (Seachem Iron): 15ml (.44ppm), 3x
GH booster: 4tsp at WC
Mg: 10mg (3ppm) at WC
Lighting: 4x55w CF, 9hours total (8hrs @ 110w, plus 1hr @ 220w)
Plants: Staurogyne, Blyxa (never done that well), H. angustifolia, needle leaf java fern
Fish: Congo Tetra x 4, SAE x 4, plus 6 or so tetras
Equipment:
Eheim 1260 (635gph) which drives AM1000 reactor
Eheim 2128 x 3
(BTW: can I post the PDF or .doc image, inside this post or must I attached it)
Bookmarks
