Results 1 to 6 of 6
Thread: Super Algae
  1. #1
    Join Date
    Jun 2008
    Location
    Chicago
    Posts
    7
    Super Algae
    In the last couple of weeks a type of algae has begun to grow on the aquarium glass that is impervious to scraping or scrubing. It looks similar to the green/olive/brown forms of algae haze that typically form slowly on the glass requiring weekly or bi-weekly scrubing. Growth is slow and it is only on certain parts of the glass (seems to be in relation to light level) none on substrate or plants. Established tank with no major algae problems. Anyone ever experience this?
    Thanks in advance for any insight
    rmjuza
  2. #2
    Join Date
    Jun 2009
    Location
    Posts
    3,205
    Blog Entries
    12
    Smile The Night Janitor Here
    Hi rmjuza,
    I will leave the whatzits and whereisiz to my betters. Others can explain the hows, whys and wherefores and tell you, you need more CO2, better dispersed.
    Think of me as the night janitor, I don’t know who made the mess or why, I just cleans it up. This is my advice.
    Procure:
    • A single-edge razor blade in a paint scraper, the kind used for paint removal (new, only for the aquarium).
    • A toothbrush stiff or medium is best new or belonging to your roommate or significant other is okay as long as they do not catch you.
    • Fleet Enema or store brand, as long as the active ingredient is Sodium Phosphate.
    • Distilled or deionized water would be nice but is not essential.
    • Turkey baster or water spritzer of some sort.
    • Paper towel or clean cloth suitable for use in an aquarium.
    Thoroughly and carefully, scrape all of the glass and stay away from the silicone seams.
    Remove at least half the water, three-quarters is better. With a toothbrush scrub the seams and any hardscape or surfaces you can reach.
    For every 10 gallons of tank volume, mix 2ml of Fleet Enema into 200ml of distilled water (distilled water is not critical.
    Sprits or baste the glass (inside) with the solution, wiping the glass thoroughly from top to all the way down under the water to the substrate. Work all the glass and any hardscape or exposed equipment all the way to the substrate.
    Refill the tank.
    If you can do another big water change in two days, that would be great, if not do not worry.
    To be on the safe side to this three weeks.
    • When in doubt "don't."
  3. #3
    Join Date
    Dec 2009
    Location
    Colorado
    Posts
    633
    Can this be used on a new tank before filling to preempt the algae without causing any issues?
    C. Smith
    1. Watt [ wot ]: noun -- the SI unit of power, equivalent to one joule per second and equal to the power in a circuit in which a current of one ampere flows across a potential difference of one volt.
    2. Per [ pur; unstressed per ]: preposition -- for each; for every.
    3. Gallon [ gal-uhn ]: noun -- a common unit of capacity in English-speaking countries, equal to four quarts.
    What does this have to do with growing plants?
  4. #4
    Join Date
    Jun 2009
    Location
    Posts
    3,205
    Blog Entries
    12
    Smile No Problem I Can See
    I see no reason it should cause a problem just separate it from any other dosing by at least a couple of hours.
  5. #5
    Join Date
    Jun 2008
    Location
    Chicago
    Posts
    7
    Biollante thanks for the advice. Sorry I didn't reply sooner I haven't had a chance to log in for a while.
  6. #6
    Join Date
    Jun 2009
    Location
    Posts
    3,205
    Blog Entries
    12
    Smile
    No problem.
    Let us know how it goes.
    Good luck,
Similar Threads
  1. Adding Sera Super Peat is it ok?
    By ccLansman in forum General Plant Topics
    Last Post: 01-27-2009, 10:36 PM
  2. Replies: 31
    Last Post: 10-08-2008, 01:35 PM
  3. Super Secret Sauce
    By reiverix in forum Advanced Strategies and Fertilization
    Last Post: 12-11-2006, 05:10 AM
  4. Super Bba :)
    By Detritus Mulm in forum Algae Control
    Last Post: 12-17-2005, 01:36 PM
  5. super substrate
    By Cornhusker in forum Off Topic and Chat
    Last Post: 09-09-2005, 05:18 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
