I know there is a lot of bad advice and mis-information out there. Thanks for posting.
"You are a child of the universe, no less than the trees and the stars;
you have a right to be here." - Desiderata
My experience and I have heard a number of folks say about the same thing.
aquariumplants.com is a wonderful place to get plants, but some of the non-plant stuff they advertise is questionable.
I have never had a single problem with any of the plants.
- I believe the information I am giving is sound, I am not a veterinarian, professional chemist or particularly bright and certainly not a "Guru.".
- I assume you are of legal age, competent and it is legal for you to acquire, possess and use any materials or perform any action in your in your jurisdiction.
- When in doubt "don't."
I was looking real hard at aquariumplants.com to get quite a few plants. I could not make up my mind which on line store to use but, now I know. Thanks Biollante.
Btw, I am getting second day air and the temp in NYC will be between 38 and 42F. Hope this is warm enough.
"Just kick in the door and the whole rotten mess will collapse."
On second day air as long as someone is available when they arrive, really should not be a problem.
Even though I have never had a problem with aquariumplants.com, I still inspect them carefully, quarantine and/or sanitize.
Good luck,
The 19:1 bleach dip is a bit harsh. Potassium permanganate is a preferred method; 1/2tbsp in 1 gal, soak for 10-15min. Some say just turn the water dark pink with PP.
- Dan
Thank you. I'll do the PP or this http://www.aquabotanicstore.com/Aqua...p/abdis-16.htm
I am with Dan, 19:1 or 20:1 bleach is harsh, Potassium permanganate, KMnO4 is a much better choice.
From a source such as aquariumplants.com, Alum (available on the spice rack in most supermarkets) will also work two or three tablespoons per gallon for a couple of hours for the microscopic bugs to two or three days for snails, snail eggs and such.
Finding PP around here is pretty tough. I've done the bleach dip. 3 minutes for the stronger/tougher plants, 2 minutes for the delicate stems/grasses. If you do this, expect HEAVY losses of leaves and high plant mortality. Swords handle this reasonably well actually, but it's still a scorched earth method.
I'll have to try the alum idea if I can find it>
Bookmarks
