Results 1 to 4 of 4
Thread: how do i determine concentrations of premixed solutions?
  1. how do i determine concentrations of premixed solutions?
    I just need some math for this one. If I have a liquid hydroponic trace solution that I want to use up that has a Fe concentration of .2% how do I determine how much to add to get a concentration of .4ppm iron in a 250L tank.
    Thanks
    100% is well, 100% of the solution, so 1,000,000 ppm, or 1 kg /liter.
    What is 0.2% of of 1,000,000?
    2000ppm or 2000mg/l
    250 liters is 250,000 mls.
    I think you should be able to work the rest.
  3. great thanks for the confirmation.
    Jan 2009
    Washington, DC
    976
    Blog Entries
    "If I only had a brain" - Scarecrow
    It's well known how bad I am at this sort of thing (bad, really bad), but you will need 50ml hydroponic trace solution to add .4ppm Fe to a water column that size.
    =.4/2*250
    = 50
    Last edited by Tug; 11-15-2009 at 03:00 AM. Reason: You should go through a bottle fairly quickly.
    Catch 22, "They have a right to do anything we can’t stop them from doing."
    Roll You're Own:
    KNO3, KH2PO4, K2SO4, CSM+B, FeDTPA, Fe Gluconate
