Hello all,
My tank is about 2 months old and for about the last 2 weeks I have thread algae slightly grown on almost all my plants but especially the most on HC at the front glass of my tank. After searched a while, it's been said that excess of iron is the cause, so I tested the water and the result was 0.5ppm and at the same time I conducted 50% WC, using brush to manually remove the algae and stop dose Seachem Iron and Flourish for 1 week, only Seachem Trace as there is no Iron substance in it. A week later after 50% WC, I tested the water again for Iron, the result was 0.25ppm and at the same time I also noticed that the algae grow back from the last spot when I manually removed them before. The sad part is my Oto's showing no desire at it
Water parameter :
kH = 1-2
gH = 1-2
pH = 6.1-7.3 (day and night, variable by CO2 with solenoid)
NO3 = 10
PO4 = 0.25 (I will raise the level to 1 later)
Fe = 0.25
Temp = 27-28C
Tank size = 80x30x40cm = 96l or 25g
Lighting = T5NO 3x21 watts on from 12-16 break 1 hour and from 17-22.
The question is :
1. Why the iron in my tank is being used real slow provided 90% of my plants are stem plants?
2. Is it true that thread algae is an iron excess cause?
I also have other questions if I may ask...
3. Why the color from my drop checker show green color on day 1-2 but will change to yellow from day 3 and on? I always clean the DC at Sunday and refill with new kH4 water (made from "Drop Checkers/CO2 Indicators-Why and How" posted by VaughnH) mix with its DC original reagent.
4. I have planted several kind of stem plants, some of them are Rotala sp. green and rotundifolia. Why the lower part of the rotundifolia's stem become black and rot (only 1 part between segment) while the lower part leaves of R. green are shattered and loose itself? Is it the lower part become lack of lighting as the plants grow bushier? But I noticed from others aquascape contest participants tank that also grow this kind of plants this way, I mean much more bushier.
Anyway, this is my tank picture of the latest condition
Any answer, help, suggestion, consideration and advice are very welcome and will be deeply thanked. Cheers![]()
? Doesn't it become toxic to fishes? And I'm too afraid if it combines with high level of K/PO4 will lead to alga bloom, no?
