Originally Posted by
A 55 gallon tank is about 21 inches tall, so with 3 inches of substrate, the substrate is about 18 inches below the top of the tank. A typical light fixture sitting on top of the tank would have the bulb about 2 inches above the top of the tank (wild guess). So, with the 3 inch legs you have, the light bulbs should be about 23 inches above the substrate. That means the light intensity at the substrate with the legs is about 20/23 times what it would be with a "standard" setup, or about 87% or less, but not less than 75%. An average of 87 and 75% is about 80%, so 2 watts per gallon with your light would be about 1.6 watts per gallon when raised that much. But, T5 fixtures give at least 1.3 times as much intensity than AH Supply type fixtures, so that 1.6 watts per gallon becomes about 2.1 watts per gallon.
All that says is that raising it 3 inches is probably not enough. I would try suspending it and raising it about 6 inches or a bit more. Remember, this is with only two bulbs, not 4. None of those numbers can be assumed to be acccurate, just a crude way to guess at how high the light fixture needs to be.
Bookmarks
