Results 1 to 4 of 4
Thread: will more help?
  1. #1
    will more help?
    'm getting lots of green all over the glass and.. plants. it mite be what you all call green dust. and i cant seem to get rid of it. i thought i mite need to add even more ferts. but even after that the algae is still coming on stong. and i was wondering if i should add even more.
    this what i have .
    55gal 4wpg 10hrs
    pressurized co2 with a drop checker using 4dkh (lime green) 6.7 ph) at 6.6 fish are gasping
    nitrate 15ppm
    phosphate 1.0ppm
    potassium ?
    iron ?
    gh 9
    dkh 11
    this is what i add using all flourish brands
    every day
    potassium 7.4 ml
    trace 7.4 ml
    nitrate 3.2 ml
    phophate 2. ml
    iron 3. ml
    flourish 2. ml.
    excel 10. ml
    and then i do 50% water changes every week.
    is this too much or do i need to add even more? to help get rid of the algae
  2. #2
    Join Date
    Sep 2007
    Location
    Posts
    5,384
    4 wpg is a lot of light. You may want to reduce it by about half or more along with the duration to 9 or 9.5 hrs a day. This will help in the long run.
    I am unfamiliar with your fert products so I cannot advise there.
    I know the experts here will soon chime in and get you going.......
    Thanks,
    Gerry.
    'When something's not right, it's wrong'. Bob Dylan
    Current 220 scape
    http://www.barrreport.com/album.php?albumid=34
  3. #3
    bump......
  4. #4
    As Gerryd said, cut back on your light. Most would say that 4 WPG is far more than you need, regardless of what kind of light it is.
    Do that and watch your plants. You might need to cut back on your dosing a bit with less light.
    Bill
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
