hey scottward,
nice to meet you mate.
As for your question about the bubble of gas at the top of the reactor, its funny because i actually dont know even if there is one, because my reactor body is regular PVC, not clear, so i can't see the bubble. I put the venturi/bleed tube only a tiny length into the reactor incase I only had a small bubble of gas at the top of the reactor. I would say maybe 1/4" of an inch into the reactor. I think mine is running correctly as far as i know, i will be testing it with some clear PVC soon to try to figure what is going on inside
the reactor a bit more.
Heres the part numbers, from REECE irrigation department. (note: these parts in total cost me $50-$60 AUD dollars, so the reactor parts for my build are quite expensive compared to Tom's which came to around $15 USD. But these parts were the only alternative i could get get to make the reactor from parts sourced here in australia.) Also my RESUN pump was quite expensive going for around $90 AUD, however as you will read froom my previous post i had troubles using a 1000LPH pump with this rector build.
1507940 - Poly Threaded Bush 4162 - 50mm x 20mm ( i got 2 of these )
1508005 - Poly Threaded Nipple - 4222- 20mm ( 2 of these )
1508125 - Poly Threaded Socket - 4366 - 50mm ( 2 of these )
1508326 - Poly Threaded Elbow M&F - 4692 - 20mm ( 2 of these )
1507940 - Poly Threaded Bush - 4162 - 50mm x 20mm ( 2 of these )
1405510 - Dwv Adaptor Pvc X MI - 50mm ( 2 of these )
I also used 20" of 2" PVC pipe (regular, not the clear stuff)
Resun Utility Pump 2600LPH that has threaded sockets for 19mm irrigation fittings (so you can just screw in the 19mm fittings into the pump outlet and use standard 19mm flexible irragation tubing for the remaining plumbing to the tank etc) [on the box the pump is rated for 3000LPH but i think the actual output is only 2600LPH i've read] If you get gas lockup while using smaller LPH rated pumps than this one, try a larger LPH pump. ( i think thats the case anyway )
Bunnings stocks the 19mm fittings, 19mm irrigation tubing and the 2" PVC pipe, i think the pipe is sold in 1 meter lengths there from what i can remember.
Pictures:
(coming really soon sorry my current camera phone is shocking, when i get my iphone back i will retake the pictures.
thx,
anteleon.
36x15x18 (40 US Gallons), True Aquatic Plants, Hailea HC-500A 1/2HP Chiller, Aqua-One 150w Halide 20000K, Eheim Classic Cannister filtration, Custom CO2 Injector (Dual venturi DIY External CO2 reactor) 6.4kg CO2 bottle Tunze Regulator Deltec AquaBee UP1000. EI + GH Booster + Seachem Flourish Excel + Casual use of Seachem Purigen chemical filtration.
Bookmarks
