The build up of gas in the top of the reactor is normal IME.
I'm running both the external reactor and in a separate tank the modified impeller power head for comparison.
I've had limited success using the venturi loop to degas the reactor during the day. As suggested to me by others I was using to small of a pump to run the reactor. I'm am currently adding a larger GPH pump to test it out.
How's yours doing using the venturi loop with the 400GPH pump?
I'm currently running a 211 GPH. From what I've seen on a 30 gal it might take a 300-400 GPH to suffice. I did run more tubing on the output of the reactor which is more than the design called for.
. Thats about 105 gph and I'm at 211 gph. Well if it's working you are having better luck than than I am. Mine seems under powered on a 30 gallon and tends to lockup. Now I just run without the venturi loop and it does fine.
Bookmarks
