I live it a very hard water area with a Tap water PH of just under 8 and very high hardness.
With CO2 and ADA substrate I'm expecting my PH to drop to somewhere between 6-7 (only just set up so not measuring anything yet).
The problem is my LFS uses the local tap water so how well are fish going to deal with the sudden shift in PH and what is the best way to acclimitise them?
Ideally I know a 2nd tank would always be the best bet but I dont really have space for it at the moment. Is this going to be the only way to do it though (have a 2nd tank with tap water PH then over the course of a couple of weeks lower the PH and hardness)?
I have read in some places that a change of PH will not cause any long term damage to your fish and just going through the normal process will be fine. But then I have read elsewhere that a PH shift of more then 1PH will stress a lot of fish close to death.
I think what would probably be worse then the change in PH would be the change in hardness (doesnt this change the osmetic pressure?)
Any advice would be great as i cant seem to find two sources that agree at the moment![]()
Bookmarks
