Venturing into pressurized system
Howdy everybody,
I've been looking into pressurized system as I'm finding that my DIY co2 is pain in the ass to keep consistent.
I've looked at Dr. Froster & Smith and Reg Riggs site... I'd like to order from online to get a pressurized system. What would you guys recommend?
I even looked at this semi-automatic system,
~Jinx~
Look Here...
Deluxe Automatic CO2 System v2.0: Aquarium Equipment and Supplies - Aqua Buys Aqua Buys Kicks @$$ !!! Quick, Outstanding Service ! Mi Dos Centavos, Prof M
I've never seen that site before, thanks Prof Myers.
Is Milwaukee products good quality and reliable? This is my first time seeing that company name.
Thanks for your help.
The Milwaukee regulator assembly can be used very well for CO2 injection in an aquarium. But, you have to be aware of its weaknesses. You have to always make sure the regulator is set for zero pressure before turning on the CO2 at the bottle valve. You have to expect leaks at the bubble counter, and either repair them some way or remove the bubble counter. You have to expect the solenoid to have a limited service life. You have to be willing to fiddle with the insensitive needle valve. But, you can do all of that, and then it works fine, and the price tends to be right.
Hoppy
Hi, I found Tunze regulator is very easy user friendly and adjusting the needle valve is not a problem either.
I think it is a german made one you can from online shops.
HTH.
Hey Jinx...welcome to the site, good to see you here.
I ordered my new one from Rex Grigg. I'm not the teckiest person around, and I had him put it together, add a low pressure regulator to prevent end of tank dumping, and also give me the capability to run 2 tanks off of one cannister. He has some good info on his site, and his a helpful kind of guy.
He has instructions there, and you can order parts from him, if you know what you are doing you can build your own. he does have some instructions...which I was too chicken to follow
Again...I think you have to know a bit more than I to do that.
I'd prefer to get something that doesn't require for me to fiddle with it on a regular basis. I'd love to have something that I can just set and forget along with few check up when necessary.
I've decided that I'd try give the local CO2 parts around here. Where would these be found? My first thought was welding store, I could look that up... but what else?
I figured that I'd try looking around first before I restort to buying supplies online. (if $ is reasonable though)
Thanks for your help guys.
Thanks nursie for the welcome
That's a start
Try your local Brewing or Beverage Supply as well. HTH. Prof M
I found 10lb tanks filled for 45$ at the local fire supply place here.
Another place will ship 20lb tanks, aluminum for 90$(that's shipped cost!).
I think David Hui mentioned that a few days ago, I can see.
I get regs on line or from Victor, Victor make the best reg's in the business.
Cost more.........then I add a nupro valve and manifold it out to suit whatever distribution needs I might have.
So a tank, a valve, a regulator, some teflon tape, the gasket between the tank/reg, some decent tubing(Tygon is great IME, but silicone is also good), a diffuser/reactor, and you are set.
You will need to watch the rate and add more every so often.
I just watch the plants, if anything is squirrlely then I check the CO2.
A reg: 20$ on ebay
Valve: 15-25$
Tanks, 40-90$
I like the Aquaticmagic.com 's ADA beetle knock off diffusers.
They run 10-25$ and are about 4-5x cheaper and similar quality
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Bookmarks
