Results 1 to 2 of 2
Thread: decreasing needle valve sensitivity by lower low pressure output, do i have it right
  1. decreasing needle valve sensitivity by lower low pressure output, do i have it right
    So i was playing with my regulator last night, I inject co2 straight into a sump pump, so i dont need high pressure for a diffuser, and i found as i lowered the output pressure, it reduced the sensitivy of the needle valve so i could adjust co2 in smaller increments it seems. Is there any downside to running lower pressure like this? My only thought is maybe this creates some fluctuation as the pressure is lower, any thoughts on this?
    With a single stage regulator, running a low working pressure will result in more psi rise when the tank runs out. That's about it though.
  1. Replies: 8
    Last Post: 03-11-2013, 05:30 AM
  2. Pressure relief valve leaking
    By peleg38 in forum CO2 Enrichment
    Last Post: 08-28-2012, 08:39 AM
  3. Victor Regulator Venting Co2 via Pressure Relief Valve
    By steve001 in forum CO2 Enrichment
    Last Post: 06-22-2012, 09:27 PM
  4. Replies: 6
    Last Post: 07-13-2010, 10:30 PM
  5. How to adjust output pressure on JBJ regulator?
    By Russ in forum CO2 Enrichment
    Last Post: 12-14-2006, 04:43 AM
