Results 1 to 3 of 3
Thread: Putting 2 filters in parallel....
    Sep 2011
    Basel, Switzerland
    11
    Hi All
    maybe this question has already been answered before...
    I have TetraTex 1200 and a 1000 lph pump that feeds a CO2 reactor, currently separated in the tank. There is a pre-filter doing mechanical filteration & then this water is drawn into TT 1200 cannister & the pump.
    Can/How should I connect the outputs of these 2 in parallel?I am less worried about the flow loss, than any back flow/pressure on the 2 pumps. The TT1200 has very less media inside & hence a good flow (havent measured it, but guess its around 800 lph at least). The pump draws the water from tank, and pushes it out of a CO2 reactor (Aquamedic type). Both have separate spray bars at the output. I would like to combine these spraybars into a single one.
    Any ideas?
    Many thanks,
    Niru
    Sep 2007
    4,863
    Blog Entries
    Quote Originally Posted by niru View Post
    Hi All
    Any ideas?
    Many thanks,
    Niru
    Make sure when you combine the two outlets you use a LARGER size diameter. You are combining say two 5/8 flows. Do not combine into a single 5/8.
    Combine into at least a 1' wye and then go from there...a larger output will flow more water but at less velocity.
    Gerry.
    Current 220 scape
    Sep 2011
    Basel, Switzerland
    11
    Thanks Gerry. I want to minimize the tubes going into my tank. Am thinking of combinings the outputs...
  1. Replies: 14
    Last Post: 08-16-2011, 09:10 PM
  2. Mazzei bypass, parallel advanced plumbing
    By Gerryd in forum CO2 Enrichment
    Last Post: 02-03-2009, 03:26 AM
  3. Perpindicular or Parallel MH Placement
    By jonathan11 in forum General Plant Topics
    Last Post: 12-03-2007, 05:24 AM
  4. Putting it all together, a good link
    By Tom Barr in forum Articles
    Last Post: 07-19-2007, 04:49 PM
