Folks,
if i where to mix K2CO3 with 500ML RODI water and i wanted to get a concentration of 3.4 PPM per 1ml squirt into 20l of water, how many grams of dry K2c03 would i need? yes i am trying to copy ADA brightly K
Folks,
let me know if my assumption is correct; if i need 75.5 grams of K2SO4 mixed with 500 ML of water to attain a 3.4 PPM in a 20l tank when using 1ml of the solution. would i need the same amount of k2co3 to attain the same concentration? being that they are both k2?
Answer to second question pm’d as it is not consistent with original question.
pm sent on 08282012:
Different Molecular Weights
No K2SO4 and K2CO3 have different molecular weights.
- I believe the information I am giving is sound, I am not a veterinarian, professional chemist or particularly bright and certainly not a "Guru.".
- I assume you are of legal age, competent and it is legal for you to acquire, possess and use any materials or perform any action in your in your jurisdiction.
- When in doubt "don't."
Clarifying question pm’d as it may not entirely consistent with original question.
pm sent 08202012
1. Is it important to that the amount added is 3.4-ppm K+ per 20-liters of water?
2. Would you prefer an amount tailored to your needs?
Biollante,
Thank you sir.
I do like the the idea of the 3.4 PPM of k per 1ml pump on 20L of water, it works well for me. so i have done some research, but i am still s bit shot. this is what i have
Molar mass of K2SO4 = 174.2592 g/mol of which 44.9% is K (is this assumption correct?)
Percent composition by element
Element Symbol Atomic Mass # of Atoms Mass Percent
Oxygen O 15.9994 4 36.726%
Sulfur S 32.065 1 18.401%
Potassium K 39.0983 2 44.874%
Molar mass of K2CO3 = 138.2055 g/mol (of which 56.6% is K)
Carbon C 12.0107 1 8.690%
Oxygen O 15.9994 3 34.730%
Potassium K 39.0983 2 56.580%
now i need to figure out the math, and this is where i need some help. Any help is highly appreciated
Pm'd...
pm sent o08202012
Re: Different Molecular Weights
Originally Posted by fplata
Thank you, so all i need to do is find out the molecular weight of both of them and the math from there? damn we need more smart people in this world so that i can continue to be dumb and happy
Yes!
Molecular weights are the sum of the atomic weights.
K2CO3 has a molecular weight of 138.21, so if anyone ever asks you for mole of K2CO3 you will know they want 138.21 grams.
- K2CO3 is 56.58% K+.
Unless your K2CO3, says “anhydrous” or “reagent grade” then it is likely K2CO3·.5H2O with a molecular weight of 147.21
- K2CO3·.5H2O is 53.12% K+.
This is a good Molecular Weight/Molar Mass Calculator.
Thank you post is appreciated.
i think i figured it out
if i want a concentration of K of 3.4 PPM when i pump 1 ML into 20 L of water I would need 76 grams of K2SO4 dissolved into 500 ML of water or 70 grams of K2c03. this is based on the molar mass. I hope i am right.
I used the nutrient calculator found at http://calc.petalphile.com/ which gave me the below formula. based on the below and the Molar masses of each on the compounds and the percentages of K each compound have i derived at the above figures.
To reach your target of 3.4 ppm K you will need to add 75.768 g K2SO4 to your 500.0 mL dosing container. Add 1.0 mL of that mix to your 20.0 L aquarium to yield
Dont Forget solubility of k2so4 in water.
You better do a lower density mix and add 4 ml of it.
Hi, PM'd![]()
pm 08202012
Potassium Carbonate for the 1-pump
Snivi is correct on the solubility, it is one of the reasons they use K2CO3 to make Brighty K, if you work real hard and the K2CO3 is pure you can get about 111-grams in for every 100-grams of water at 20°C.
Remember for these numbers to work correctly the total solution must be 500-ml, so that 70-g K2CO3·.5H2O is added to 400-ml distilled water then enough water is added to make 500-ml. (Without getting too technical, the K+ in solution is actually somewhat greater than calculated, but figure impurities and so forth make it accectable.)
Whereas with K2SO4 if you work real hard it is only about 13-grams in for every 100-grams of water at 20°C. Therefore, if you are going to use K2SO4 realistically you need to mix the 76-grams into 900-mililiters of distilled water and add enough distilled water to make 1000-mililiters, then dose 2-mililiters per 20-liters to get your 3.4-ppm.
Or use Snivi’s formula and add 38-g K2SO4 to 950-ml distilled water and top off to make 1000-ml and dose 4-ml for every 20-l to get about 3.4-ppm.
Thank you everyone!
Bookmarks
