Results 1 to 2 of 2
Thread: Sera Plant Care Set - With Co2 reactor
  1. Sera Plant Care Set - With Co2 reactor
    This set comes with a "co2 reactor" and "tabs plus" apart from the other fertilizer stuffs. As stated on the instruction sheet, this unit needs to be placed just below the water surface.
    Step 1: i placed the unit just below the surface of the water
    Step 2: then i fixed in the rubber stopper
    Step 3: i dropped 1 tablet into the given slot
    Step 4: gas started generating and small bubbles started to disperse into the tank thru small holes below the reactor.
    Step 5: Lasted only 30 seconds
    Step 6: No bubbles left, everything is finished
    I cannot re-try as i have already used 1 tablet/ will try again after 1 day.
    Have i done sumtin wrong or is it this way it is done.
    Please advise./ went for this as i was advised and read many sites that seachem excel is bad for vals and egeria... which i have in the tank...
    Appreciate prompt response.
    Do you have a link to the product?
  1. Sera Flore Active 1000 reactor problem
    By pleco4me in forum CO2 Enrichment
    Last Post: 06-10-2012, 07:57 AM
  2. In transit plant care questions
    By pepetj in forum General Plant Topics
    Last Post: 04-07-2011, 03:41 AM
  3. Would someone care to humer me!!
    By Gbark in forum Aquatic Plant Fertilization
    Last Post: 07-25-2010, 05:47 PM
  4. Adding Sera Super Peat is it ok?
    By ccLansman in forum General Plant Topics
    Last Post: 01-27-2009, 10:36 PM
  5. Substrate care
    Last Post: 01-25-2009, 03:27 AM
