Results 1 to 2 of 2
Thread: Sump filter media? Best to use?
  1. Sump filter media? Designs? Best to use?
    Just wondering what people considered to be the best filter media for a FW sump/wet/dry filter?
    Bioballs? K1? Etc?
    Let me know what you use or recommend?
    Planning on setting up my first overflow/sump system and need some advice.
    Also after some sump design ideas? How to compartment the sump, etc.
    Cheers
  2. #2
    Join Date
    Aug 2010
    Location
    Ft Lauderdale FL
    Posts
    426
    You know I went through this recently. So two years ago I thought I would build my own sump using a 55 gal tank. Twin sock filters with a 30 g sump area. Bio balls. It worked ok. The sock filters kept clogging up. Couldn't polish the water. A month ago the acrylic partitions separated from the silicone and I decided to buy an eshopps regular wet dry.
    I used my bio balls from the current sump and used CPR bio bale. We use bio bale at store and we love it because it has a greater bio area and it is easy to clean. You grab whole gallons at a time and swish it in a bucket of ro water. Instead of hundreds little balls rolling all over the place.
    So the wet dry comes with pads but I used a foam pad from cobalt that I can cut to size for the drip tray. It is washable at it does not clog like the normal pads. In the pump area I use several sponge blocks. They trap a lot of debris.
    This whole setup is much easier to maintain. Even though I loSt 20 gals of sump/water volume it was well worth it.
    Henry Tomassini
    www.theplantedaquariumstore.com
    "If it ain't broke, Fix it!
    - because you will not be satisfied until you do"
    The ONLY store dedicated to the planted Aquarium Enthusiast
    http://www.theplantedaquariumstore.com
Similar Threads
  1. ceramic filter media replacement?
    By ibanezfrelon in forum General Plant Topics
    Last Post: 12-20-2010, 05:30 AM
  2. Filter Media - what's the recommended media?
    By Co2 in forum General Plant Topics
    Last Post: 10-18-2010, 01:43 AM
  3. What Filter Media to use?
    By herns in forum Are you new to aquatic plants? Start here
    Last Post: 02-14-2009, 05:01 PM
  4. Biological Filter Media
    By shane in forum General Plant Topics
    Last Post: 05-17-2008, 07:48 AM
  5. Sump Filter Media
    By jonathan11 in forum General Plant Topics
    Last Post: 08-25-2007, 03:23 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
