Results 1 to 8 of 8
Thread: Maintenance 101
    Maintenance 101
    Will some you fellow aquarists share you water change procedure with me and critique mine?
    Here's how I do mine:
    Turn off filtration and CO2.
    Run hose from tank to sink (connected to waterbed fill/drain adapter)
    Adjust adapter to drain and momentarily turn on water at sink to create siphon
    Once siphon is active, use hose end at tank to suck up detritus
    Once I've sucked up the detritus, I just let the water drain until approx 75% of water is removed.
    Now I'm ready to fill the tank, so I turn on the sink and mix the hot and cold until the temp coming out of the faucet is the same as the tank.
    I place a dish into the tank and clamp the hose so the output hits the dish.
    I then switch the adapter from drain to fill, and begin filling the tank.
    During the din and fill time, I clean my Eheim (once a month).
    When the water is approx. a couple of inches from the top, I turn on the filtration and CO2.
    When the water has reached the top, I turn off the faucet and remove the hose from the tank.
    I then add (3) teaspoons of superbuffer dKH and (10) teaspoons of GH Booster.
    The End.
    I am here: http://tapatalk.com/map.php?4zrcs5
    75G high tech
    Sent from my iPad using Tapatalk
    Jun 2009
    Surprise, AZ
    3,205
    Blog Entries
    12
    Smile Lake Malawi Biotope? Sounds Fine To Me...
    Do you use dechlorinator?
    Since you are not trimming plants, I am guessing it is not planted, sounds fine without knowing size of tank intentions, water quality, Lake Malawi, brackish water, marine so forth.
    The first sign we don't know what we are doing is an obsession with numbers. - Johann Wolfgang von Goethe
    Disclaimer: I am not trying to make you mad, it is just what I am, an evil plant monster, 'nuf said.
    • I believe the information I am giving is sound, I am not a veterinarian, professional chemist or particularly bright and certainly not a "Guru.".
    • I assume you are of legal age, competent and it is legal for you to acquire, possess and use any materials or perform any action in your in your jurisdiction.
    • When in doubt "don't."
    Jun 2012
    Richmond Hill, ontario
    35
    I've always been worried about turning on the hot water bc of the increased copper in it..is this just worrisome for shrimps?
    Hi Biollante. I don't use a dechlorinator on the water supply. I know it's been a little while, but you helped me with my EI dosing regimen in the following post: http://www.barrreport.com/showthread.php?t=10170
    Very helpful I must add.
    The tank is planted and I do prune the plants. Forgot to mention that in the outlined process. The tank is 75g.
    What inspired my post is that my population of 7 mollies seem quite stressed with the water change. When I fill the tank, they all hide. It takes about an hour for them to start re-appearing.
    I am here: http://tapatalk.com/map.php?hjbomh
    75G high tech
  5. #5
    Quote Originally Posted by Jiinx View Post
    Hi Jiinx - I'm not sure how hot water would have any different copper value than cold. If its related to the water heater, I have a tankless heater.
    I am here: http://tapatalk.com/map.php?qmh12y
    75G high tech
    I wonder if the affect on the fish is due to a rapid change in PH. I have to buffer my tap water.
    I am here: http://tapatalk.com/map.php?mprpye
    75G high tech
    One or both fixes virtually any aquarium problem fast.
    You can simply run the hot water a few min to get any residual out of the lines prior to use.
    Organic matter and plants tend to remove copper rather quick in our tanks.
    At higher pH's, the metal will not dissolve nearly as much.
    It can get a nice crusty filmy marl layer on the inside from Mg and Ca carbonates.
  8. #8
    Jun 2009
    Surprise, AZ
    3,205
    Blog Entries
    12
    Smile Add Stuff As You Add Water
    Okay I remember now. I pretty well remembered but being lazy and not wanting to make more of a fool of myself then normal, I treat each thread as self-contained.
    Glad it is working out for you.
    Two possibilities leap to the first is that with no dechlorinator the, the chlorine is causing distress, being Mollies I tend to doubt this is the cause. Unless there is heavy, chlorination going on there is generally not enough chlorine in tap water to harm our plants or critters. Arguably the residual chlorine from the tap is neutralized by oxidizing organic material in the tank.
    I tend to think you are correct, perhaps not pH per se, but I would add the boosters as you are refilling the tank, especially if you are adding baking soda.
    It does not hurt to run cold and hot for a minute or two, but unless it is a lot of Copper, organic material in our tanks tends to chelate the Copper, effectively sequestering it and letting the substrate deal with any excess.
  1. Diffuser Maintenance
    By The Rockster in forum CO2 Enrichment
    Last Post: 09-16-2009, 05:52 AM
  2. Hi tech, low maintenance
    By jonny_ftm in forum Estimative Index
    Last Post: 06-02-2009, 11:20 AM
  3. NC - canister maintenance?
    By Gerryd in forum General Plant Topics
    Last Post: 09-27-2008, 07:19 AM
  4. 90 gallon low maintenance setup
    By eddtango in forum General Plant Topics
    Last Post: 11-18-2006, 06:51 PM
  5. Low-light, growth, maintenance
    By Kevmo in forum Advanced Strategies and Fertilization
    Last Post: 01-23-2005, 08:17 PM
