Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Problem with ISTA Reactor
  1. Quote Originally Posted by Htomassini View Post
    The reactor is doing what it's supposed to do. Mix co2 with running water. You stop the water flow and it will flood the reactor with co2. Do you have this on the intake or outflow side? If you have it on the outflow side and you have it mounted vertically the co2 should be creeping upward to the outflow pipe and into the tank. Normally a gas will not flow down. Do not connect this on the intake side.
    Henry tomassini
    www.theplantedaquariumstore.com
    Sent from my iPad using Tapatalk HD
    The connections are made as shown in the manual.
    The reactor is mounted vertically, the inflow is from the side of the reactor, the outflow is from the top of the reactor.
    When gas starts accumulating it should come out from the outlet side and not back towards inflow side into the Canister.
    The Manual or the website do not state anywhere that a solenoid is required for proper functioning of the reactor.
    This should have been mentioned on the product description.
    As of now I have taken out the reactor and it is lying useless for me.
  2. #12
    Join Date
    Jun 2009
    Location
    Posts
    3,205
    Blog Entries
    12
    Smile The More CO2, The Faster Dutchy Ends Up With A 1st Floor Apartment
    I use CO2 reactors very similar to yours and know of no requirement for a solenoid.
    A solenoid would be one answer to the power outages. Power off solenoid closes, no CO2 to “airlock” the canister filter.
    A check valve on the output side of the canister filter should prevent the CO2 from backing up into the filter and dump it into the tank instead.
    Another answer is to use a separate pump, an inexpensive submersible pump in place of the canister filter output the power goes off so does the pump, the CO2 ends up in the tank.
    • When in doubt "don't."
  3. #13
    Join Date
    Aug 2010
    Location
    Ft Lauderdale FL
    Posts
    385
    Solenoids are usually mounted on the regulator before the needle valve, red sea makes one that can be used on the plastic tubing. You did not answer my question regarding the reactor, did you mount the reactor so the water comes from the outlet side of the cannister filter?
    "If it ain't broke, Fix it!
    - because you will not be satisfied until you do"
    The ONLY store dedicated to the planted Aquarium Enthusiast
    http://www.theplantedaquariumstore.com
  4. Quote Originally Posted by Biollante View Post
    I have already started using a small submersible pump in place of canister filter out put, the problem is no longer there.
    Sometimes the easiest of solutions can be elusive.
    @ Htomassini
    The input of reactor is connected to output of canister.
Similar Threads
  1. Sera Flore Active 1000 reactor problem
    By pleco4me in forum CO2 Enrichment
    Last Post: 06-10-2012, 07:57 AM
  2. Problem with external CO2 reactor
    By Eudmin in forum CO2 Enrichment
    Last Post: 03-10-2012, 04:20 PM
  3. Problem with HC?
    By Pale Rider in forum General Plant Topics
    Last Post: 03-17-2009, 09:37 PM
  4. DIY Reactor VS RedSea Reactor 500
    By chonhzilla in forum CO2 Enrichment
    Last Post: 06-06-2008, 01:56 PM
  5. co2 problem
    By Cornhusker in forum General Plant Topics
    Last Post: 05-05-2005, 12:05 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
