Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Anyone Using Ecoxotic Stunner LED Strips or Truelumen Pro LED Strips?
  1. #1
    Is anyone using Ecoxotic Stunner LED Strips or Truelumen Pro LED Strips exclusively to light a planted tank? I would like to do the same if I can find someone who has had success using either of those without other lighting.
  2. #2
    Join Date
    Aug 2010
    Location
    Ft Lauderdale FL
    Posts
    385
    We have experience with them at the store.
    The stunners are good for about 15 par on a std 30 long tank. (single strip 6 inches above tank)
    We use them in our sell tanks and crypts and some swords grow with it.
    The true lumen are more powerfull. They will put out about 30 par on an 18" high tank at tank height. I use it to supplement a double t5 on a 33 gal high tech tank.
    let me know if you need more help on this.
    Henry tomassini
    www.theplantedaquariumstore.com
    Sent from my iPad using Tapatalk HD
    "If it ain't broke, Fix it!
    - because you will not be satisfied until you do"
    The ONLY store dedicated to the planted Aquarium Enthusiast
    http://www.theplantedaquariumstore.com
  3. #3
    Thanks for the reply. I posted the same question on three forums, getting a lot of views but only your reply. I've been researching this project (low tech,no CO2, soil under gravel) for over a year and lighting has been the biggest challenge. I was sold on T5 until I started reading about LED. I like the idea of longer life and less power consumption. The start up cost is a little high but I can live with that. I'm not much of a DIYer so that led me to the two different strips which can be easily attached to a canopy lid. I need to learn more about par but if all I need to know is higher is better, I should go with True Lumen, right?
  4. #4
    I have both - Stunners as supplemental lighting over a reef and newly placed TrueLumen Pro in 8,000K over a 12G long. Here's the PAR I'm seeing from the TrueLumen Pro...
    Adding the the docking feet raise the fixture 1.5". It looks nice with the back etched as well...
    I really like the quality of the light 8,000K light.
    -Tom
    The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. - George Bernard Shaw
  5. #5
    Thanks for the reply. Between the two strips, which one do you think would provide more light?
  6. #6
    Quote Originally Posted by kshafer View Post
    Easily the TrueLumen Pro. If by chance you've got too much PAR, you can add an dimmer.
    -Tom
  7. #7
    Thanks for the reply. That's exactly the information I am looking for.
  8. #8
    Join Date
    Aug 2010
    Location
    Ft Lauderdale FL
    Posts
    385
    Yes the inline dimmers are now available. Let me know if you want them. I have them in stock.. When I redo my 210 I'm ditching my useless 8x 80 ho t5 unit and going with 5 x 36" units. I will prob do 4 8k and one 12k in the middle.
    Henry tomassini
  9. #9
    Do you think the Stunners provide enough light? I'm thinking about four 36" strips over a 180 gallon and the Stunners would be considerably cheaper.
  10. #10
    I won't be much help in determining stunner PAR - I use 403nm Stunners as supplemental lighting over a reef and due to the spectrum, it's hard to get PAR measurements with an MQ-200. My brand-new-to-planted, uneducated guess would be the stunners would not be enough. I would add that between the two choices, the TrueLumen Pros are much higher quality.
    -Tom
Similar Threads
  1. LED's by Ecoxotic?
    By Cyclesafe in forum Lighting
    Last Post: 02-19-2011, 06:19 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
