Results 1 to 3 of 3
Thread: DIY Custom Filter Setup Thingy
    I have been reading the forums for a while and I need some advice from you very knowledgeable folks.
    I am drawing up some plans for a DIY external filtration setup.
    So far I am thinking that I would like to build a wet/dry filter, external heater, dosing pump, probe array (more of an accuse to play with electronic than anything else!) and a CO2 reactor.
    The tank I will be installing this on is a small 10g tank (prototype tank before upscalling to my bigger tank). I plan on drilling the tank to incorporate an overflow system to feed the filter setup. I have never drilled a tank before so I will probably end up breaking it and getting a pre drilled one! I will cross that bridge when I come to it.
    Specifics aside I am trying to work out the order of the equipment within the setup, so far I have this in my head but I would love to hear you opinions/advice:
    Tank Overflow>>>Wet/Dry Filter>>>Dosing Pump>>>Return Pump>>>CO2 Reactor>>>Heater(s)>>>Probe Array>>>Tank Outlet
    Do you think I should try and oxygenate it as well or just create some surface movement within the tank?
    Error - Signiture Missing - Pressumed Dead
    Jun 2009
    Surprise, AZ
    3,205
    Blog Entries
    12
    Welcome!
    Sounds like a plan…
    Wet/dry filters tend to be well oxygenated.
    The first sign we don't know what we are doing is an obsession with numbers. - Johann Wolfgang von Goethe
    Disclaimer: I am not trying to make you mad, it is just what I am, an evil plant monster, 'nuf said.
    • I believe the information I am giving is sound, I am not a veterinarian, professional chemist or particularly bright and certainly not a "Guru.".
    • I assume you are of legal age, competent and it is legal for you to acquire, possess and use any materials or perform any action in your in your jurisdiction.
    • When in doubt "don't."
    Damn!
    Thanks Bio getting a better idea of where i am going with this now.
    As predicted I broke the glass!
    It was going well untill I lost my patience with it and applied to much pressure. Never mind its all a good learning experience.
    I should be picking up a new tank this weekend and making a custom built stand for it.
    Then I can get back to playing with water!
  1. Custom Co2 regulators built just for you
    By oldpunk in forum Trades, swaps, sales
    Last Post: 06-08-2011, 01:32 AM
  2. New Custom CO2 Set up
    By trd1 in forum CO2 Enrichment
    Last Post: 04-14-2011, 12:44 PM
  3. Co2 Regulator, Custom
    By Addict in forum Trades, swaps, sales
    Last Post: 04-06-2011, 11:12 PM
  4. wet's thingy
    By Wet in forum Advanced Aquascaping and Design
    Last Post: 07-08-2010, 11:55 AM
  5. Pricing a custom tank
    By crystalview in forum Are you new to aquatic plants? Start here
    Last Post: 02-08-2009, 03:20 AM
