Here is a picture of the new packaging for all of the dry ferts:
Dry Ferts- Ala Carte
Potassium Nitrate (KNO3)- $3/lb
Mono Potassium Phosphate (KH2PO4)- $5/lb
Potassium Sulfate (K2SO4)- $3/lb
Miller Microplex- $9 per 1/2lb or $17/lb
Plantex CSM+B- $12/lb
Iron Chelate 10% DTPA- $10 per 1/2lb, $18/lb
Iron Chelate 13% EDTA- $9 per 1/2lb $8/ half lb, $14/lb
Magnesium Sulfate (MgSO4)- $2.50/lb
Manganese Sulfate (MnSO4)- $8/ half pound
Calcium Nitrate (CaNO3)- $2.50/lb
Calcium Sulfate (CaSO4)- $3/lb
GH Booster- Contains 3:3:1(K2SO4:CaSO4:MgSO4)- $6/lb
-Shipping will be $6 no matter how much is ordered, unless otherwise noted-
Package Pricing
NPK + CSM+B Package- $20 shipped
1lb KNO3, 1/2lb KH2PO4, 1lb K2SO4, and 1/2lb CSM+B
Add 1/2lb of Iron Chelate 13% for $7 or 1/2lb Iron Chelate 10% for $8.50
NPK + microplex Package- $22 shipped
1lb KNO3, 1/2lb KH2PO4, 1lb K2SO4, and 1/2lb miller microplex
EI based NPK + CSM+B - $22 Shipped
2lb KNO3, 1/2lb KH2PO4, 1/2lb K2SO4, and 1/2lb CSM+B
EI based NPK + microplex Package- $24 Shipped
2lb KNO3, 1/2lb KH2PO4, 1/2lb K2SO4, and 1/2lb Miller Microplex
Micro/Macro Mix- $10/pound $18 for two pounds plus $6 shipping NOW IN STOCK
Contains:
Miller Microplex
Liquid NPK + M
Dosing for full EI levels is 1 pump of each bottle per 10 gallons 3x per week.
For lower light/lower tech tanks dosing at 1 pump per 20 gallons 3x per week.
For example: For a 20 gallon higher light tank would be as follows-
2 pumps of the micros per day Monday, Wednesday and Friday.
2 pumps of the macros per day Tuesday, Thursday and Saturday.
50% week water change is suggested on the 7th day per EI guidelines followed by addition of the GH booster of your choice(I have some for sale below in the dry ferts section).
Bottles are 16oz each.
This will last more than 41 weeks on a 20 gallon tank dosing 3x per week.
I am asking $29 shipped
DIY EI Liquid Ferts
Want to dose ferts but the cost of liquid ferts is too expensive???
Dont want to go through the hassle of mixing dry ferts yourself???
Then this is for YOU!!!!!!
What you get- 2x 500ml dosing bottles(1x Micros, 1x Macros)
2 complete refill packets( so you are essentially getting enough to make 1500ml of both micros and macros)
Cost- $28 shipped
It will be shipped without water, all you will need to do is add 500ml of RO water to each bottle. When the solution in each bottle runs out, simply add the refill packet to the appropriate dosing bottle and add 500ml of RO water and you are good to go again.
Dosing Instructions:
Add 5ml per 20 gallons of water for each the micro and macro 3x per week on alternating days per the EI dosing instructions.
How long will this last me??
20 Gallon tank- roughly 2 years
40 gallon tank- roughly 1 year
80 gallon tank- roughly 6 months
and so on...
Special thanks to WETS dosing calculator:
Warning: Micro solutions will sometimes grow mold, to prevent this you should either refrigerate it or add 10ml excel to the solution
Concentrations(as per wets calculator):
Micro-
B- 0.09ppm
Cu 0.01ppm
Fe 0.50 ppm
Mg 0.11 ppm
Mn 0.14 ppm
Mo 0.0038 ppm
Zn 0.03 ppm
dGH 0.02
Macros:
N- 7.5ppm
P- 1.3ppm
K- 4.27ppm
PPS-Pro Liquid Ferts
PPS-Pro style liquid fertilizer- $27 shipped
Includes:
-2x 500ml dosing bottles
-Pre-measured micros and macros, enough to dose 5000 gallons of tank water.
-Also comes with set of refill packets
Additional refill Packets are $6 per set.
The ferts will come already in the dosing bottle, simply fill the bottle with 500ml of RO water and you are ready to go.
Dose 1ml per 10 gallons of water of each micro and macro ferts each day prior to lights coming on.
NEW MTS/EI/CLAY Capsules-
50 [HASHTAG]#000[/HASHTAG] capsules for $14 shipped
These Comprise of:
75% Mineralized Top Soil
25% EI+Clay formula(16 parts Red Clay, 8 parts CSM+B, 2 parts Potassium Sulfate, 2 parts Magnesium Sulfate, 0.5 part Potassium Nitrate)
OSMOCOTE+CAPSULES
For sale are 00 sized capsules filled with Osmocote Plus. I am selling them for the cheapest I have seen them sold. Get them while they last.
The capsules are-
-BSE Free Certification-
-Gelatin Capsules -
- Halal Certificate -
-Kosher Certification -
Options-
Prices include first class shipping - add $3 for Priority
25 - $5
50 - $8
75 - $10
100 - $11
150 - $12
200 - $17
300 - $20
Package Pricing
Contains:
Miller Microplex
Liquid NPK + M
DIY EI Liquid Ferts
Cost- $28 shipped
and so on...
Micro-
B- 0.09ppm
Cu 0.01ppm
Fe 0.50 ppm
Mg 0.11 ppm
Mn 0.14 ppm
Mo 0.0038 ppm
Zn 0.03 ppm
dGH 0.02
Macros:
N- 7.5ppm
P- 1.3ppm
K- 4.27ppm
Includes:
These Comprise of:
OSMOCOTE+CAPSULES
The capsules are-
-Gelatin Capsules -
Options-
25 - $5
50 - $8
75 - $10
100 - $11
150 - $12
200 - $17
300 - $20
