I've decided to convert my main tank (50G) to non-CO2 for now, because I want my tank to be more maintenance free -- I've been spending a lot of time traveling (by my standards), and I think this is my best option (at this time).
I've read up on the non-CO2 method (Tom's version) and understand the basics. Luckily, most of my plants should do fine in a non-CO2 environment, so I will not have to do much re-scaping. I put together a 10G non-CO2 tank a number of months ago, and it has been doing quite well. However, the one thing I'm not sure about is filtering, so here are some questions:
1) Should we still go for a high flow rate on a non-CO2 tank? I was thinking to go about 400 gph.
2) Do we still filter the water very well? It seems that a non-CO2 is more of a self-contained eco-system. I was wondering if perhaps it's a good idea to filter less so detritus (decaying leaves, e.g.) can dissolve and be re-used by the system. I've actually been working on a DIY sump and have some very fine filter socks I was planning to use. I'm not even sure that I should use these on a non-CO2 tank (maybe a sump isn't even a good idea).
Thanks in advance.
Thanks in advance.
