Dry start: My first attempt on a 11gal nano
  • Dry start: My first attempt on a 11gal nano
    Thanks to the help and tips of Tom, Philosophos and many other members that helped me choosing the light... I could start my first nano, dry, on teh 27 june, so 2 weeks ago
    Soil is mix of earthworm casting (bio label) + Flourite Black Sand, topped with Flourite Black Sand
    Light is 2x11W ArcPod PC light
    Tank is an Aquatic-Nature cocoon 7 (11 gal rectangular)
    The plants are doing very well and I didn't have yet any trouble with the Tenellus. The Cryptocoryne Parva didn't melt and the P. Helferi is already growing. I also chose plants that were just arrived to the shop from Dennerle, so emerged growing and easier to acclimate to a dry start
    Humidity is maintained near 80-85%
    >>Follow it here<<
    And, now, after 15 days (sorry, but front view is difficult because of condensation that I can't remove fearing to alter the glass with some sand)
    The recipient is to help maintain good humidity. And 2 calibrated Hygrometers to monitor hygrometry reliabely
    >>Follow it here<<
      I don't remember seeing anyone try a dry start with those plants. They look great now! This will be very interesting to watch for the next few weeks.
        Looks like the dry start method is working very well for you. I might just have to give it a try.
        Good to see the E. tenellus looking healthy; it certainly goes well with the P. helferi.
        -Philosophos
          Cool!
          Great photos!
            Thank you for the comments,
            I chose those plants because I'm targetting a low maintenance shrimp tank. I'll use CO2 though. I renounced to use Excel because of safety concerns raising on some forums
            Stems, anubia, java fern and other crypts will not be grown emersed as I have them growing in my main 60gal
            I'm especially happy to see the parva and tenellus so healthy after 2 weeks. I saw other expieriences with tenellus rotting very quickely and C. Parva melting.
            It suerely helps starting the tank in summer as it is easier to maintain constant temperature/ventilation/humidity. Also, using my cycled aquarium water rich of NPK-micro and mulm from it helps the plants to establish for sure
            I'm still waiting for new emerged leaves though to be sure I'm on the good way
            >>Follow it here<<
              Excel (glutaraldehyde) is something you can get along without just fine. It isn't so dangerous as people make it seem though. Most problems happen when people ignore established dosing ranges, and don't bother to check how sensitive the species they keep are to the chemical.
              Glutaraldehyde can be used to increase hatch rates at one level, and sterilize them at another. It's a matter of dose. You don't need to worry about cumulative effects of excel either; it's got a half life around 11 hours.
              Again, not saying it's necessary to use it, but it can be a helpful product. Spot treating algae on hardscape that can't be moved without disturbing plants is usually how I end up using it.
              -Philosophos
                There's a long debate, now locked, on UKAPS about its safety for human on the long term
                I don't like to debate it here, in this topic, especially as the silence from seachem and other companies using such product is complete.
                Here's the UKAPS link:
                UK Aquatic Plant Society Forum &bull; Login
                You can read through it and, if you like, open a new topic on these concerns maybe
                >>Follow it here<<
                  I have a big issue that I need your help. I'll submerge the tank in about 2 months and wondering about the placement.
                  I'd like to put it facing 2 big french windows, so consistent direct daylight, but no direct sun light. I'll be going for pressurized CO2, yet with my rather low 2x11W PC lights and slow growing plants.
                  Do you think placing such a setup in front of these french windows is asking for trouble on the submerging phase?
                  Otherwise, emerged foliage is getting denser on the Helferi, tenellus is sending shoots with new leaves and the Parva is still so beautiful, no melting
                  >>Follow it here<<
                    Light gets a little tricky when it comes to outside sources. Outside of finding access to a PAR meter, about all you can do is eyeball it, and adjust. A lux meter would be cheaper to get your hands on, and it would allow you to at least compare one level of light to a previous amount.
                    -Philosophos
                      I know ambient light is a touchy subject, my experience with four tanks in a high ambient light area has been good.
                      The rather strong daylight has had the net effect of turning the three tanks with no artificial lighting into low to perhaps even moderate light tanks. My two watt per gallon tank into a high nutrient consumer, high growth tank.
                      Most shocking to many is that for at least part of the year (winter) all tanks get at least some direct sun. One tank gets as much as four hours a day of sun.
                      As with all tanks it will of course most depend on your plants and your routines.
                      I would assume you would wish to account for the extra light, driving consumption and growth. I would say keep the CO2 levels and err to the high side on nutrients.
                        Many thanks to both of you. I was afraid of daylight because of all what we read in the net: "daylight drives algae soon or later"
                        Indeed, with EI, we better understand algae ad plants needs.
                        So, I'll put this nano where I like it, so well exposed, and go on with CO2 and nutrients as needed. Maybe I'll have to decrease my lights to keep it low maintenance, we'll see
                        Thank you again for your help.
                        Soon, I'll post a new top comparative shot to visualize plants growth. I'm so happy with this dry start seeing how the plants are doing. I'm now getting new shoots of every thing and spaced my misting to 1-2x/week only. It should be 1-2x/3-4 weeks easily later as the substrate remains really well immersed
                        >>Follow it here<<
                          Well thanks for sharing this dry start. I am going to give this a shot.
                          It reminds me of a high school project back when...
                            Here's some news.
                            It's growing very well, no problems, not any crypt melting. The P. Helferi is getting bigger in size and is well rooted, far better than the ones planted in my 60gal since 2 months :-(
                            The C. Parva is the slower but new leaves are out and old ones still great looking. E. Tenellus is giving me some concern. It really doesn't behave like usual swords: fast growth, old leaves decay too quickely. I hope it will get slower once immersed with less debris from old leaves decaying too quickely like a stem plant. My first concern was a low maintenance tank and I won't keep with pruning the Tenellus if it will grow that way all the time :-(
                            Any idea on another plant I could replace the Tenellus with? Blyxa?
                            Ah, and here are the shots, I modified the small rock on the left and will be pruning the helferi for the layout in few weeks
                            And a top view to compare the growth with the previous shot, 3 weeks later, and after having pruned the tenellus from decayed leaves
                            PS: a great thank to Tom for his best ever starting method
                            >>Follow it here<<
                              I'll be following your lead Johnny.
                              I'm setting up mine tomorrow and hoping for the best! (otherwise I just lost $100 worth of plants !! )
                              Please give us an update when you have a moment.
