Tom: Disk Diffusor or Venturi Internal Reactor?
  • Tom: Disk Diffusor or Venturi Internal Reactor?
    Tom,
    I'm now injecting Co2 via an in-line reactor into my 40 gallon. I've read your recent Co2 article and threads since then and I have to admit to some confusion (probably my denseness) as to what method you currently think is the best way to go. Are you recommending
    1. a ceramic disk diffusor (such as the Eheim, Boyo or Azoo (do you have a preference?)) under the spraybar or
    2. Using an internal venturi reactor such as you've got diagrams on this site?
    Peter
    Re: Tom: Disk Diffusor or Venturi Internal Reactor?
    Either, the best mist seems to be when the disc are used.
    Making sure they produce consistent bubbles/sizes etc is a key element though.
    Internal venturis are eseential maintenance free and take up more space.
    You can split the line and add CO2 via disc and reactor also.
      Thanks. I'll try a disk diffuser and see how it goes.
        One other tag along question. Should you disregard pH control with the CO2 mist method? I currently have a my pH controlled at 6.7-6.8 running into an internal powerhead reactor. Should I just remove the reactor and pH controller and run a couple of disk diffuser below the pump outlets?
        Tank is 75gallon.
