The Estimative Index of Dosing, or No Need for Test Kits
Status
Not open for further replies.
Greg Watson
Administrator
Staff member
Administrator
Jan 23, 2005
5,023
3
38
United States
The Estimative Index - What is it?
The Estimative index is a simple method to dose nutrients for any tank without test kits. In a nut shell, the aquarist doses frequently to prevent anything from running out (plant deficiency) and does large weekly water changes to prevent any build up (Plant inhibition). In this manner, we can easily maintain a close approximation or an “estimation index” of the nutrient levels during the week, not too high, not too low and…..no need for a test kit because the accuracy is close and in most cases closer than a test kit. This uses a common habit that most aquarist already are doing and are familiar with, the weekly water change. I’ve done numerous test runs over a week or three week time period using very high light (450 micromoles/m^2/sec @ 8 cm from light source) and many different species of fast growing stem plants. This will give an assumed “maximum uptake rate”. This rate is important in setting the upper limit of the needs of the plants. Once the aquarist knows this rate, they can be confident that they are not going to run out of any nutrient at most any lighting variable. This “rate” of uptake or dosing is what is truly important rather than maintaining some static “residual” level. A stable range is all that's needed for good healthy growth. This range concept is supported by observations from many people all over th world with a variety of tap water qualities, as well as review of the relevant research in the Barr Report volumes 7 and 8, 2005. This range has proven to be quite large on the upper limits. With a general 50% weekly water change, the aquarist will build up a maximum of 2x the dosing they add per week. So if you want to maintain 10-20ppm of NO3, this is quite easy to do with out ever picking a test kit (see figure 1 below and the example). Similar ranges can be targeted for the other nutrients and narrower ranges can be achieved using the fertilizers diluted in water.
These maximum rates are also variable, but the rates I am suggestion are only a guideline, different plants and different set ups may use more, but the plants will not run into deficiencies at these rates. The aquarist is not limited to 50% weekly water changes, they can change more precentage, for example 75% and this re sets 75% of the water volume just like making a standard solution for measuring and calibrating a test kit. More frequent water changes can also be performed, but hitting the target set by the aquarist can be achieved relatively easily for those less confident of 50% weekly changes.
Plants can take up more than they need for growth, something called "luxury uptake". The other issue is that a plant might be starved for a nutrient and the uptake rate may be very rapid in the first few weeks then taper off later. This is referred to as “surge uptake”.
Some Typical uptake rates at high light and CO2 levels per day (24 hours):
NO3 1-5ppm
NH4 0.1-0.8ppm(if you use this in place of NO3)
PO4 0.5 ppm
These rates do not assume that you will show deficiencies if you dose less than this, but adding more than these rates will not help further plant health.
This is a point that the aquarist needs to understand. Basically, it is extremely unlikely your plants will ever need more than these rates even at high light intensities. Adding enough nutrients to prevent anything from becoming deficient is the goal, not precise uptake and growth requirements.
Note: these ranges and test in this article used Hach or Lamotte test kits and where checked against known standard solutions. Most hobby grade cheap test kits often are inaccurate and create many problems for aquarist. While some may work, it is always a better idea to check the test kit against and known standard. This way you verify the accuracy and this is what is done in research science. Do not assume that a test kit is accurate. This causes a great deal of frustration, confusion and poor horticulture and was one of the main reasons I suggested this idea for dosing.
The need for such precision is not needed as plants have a very wide range of nutrient concentrations (BarrReport volume 5,7 and 8, 2005) that are above the deficiency level before excess nutrients level become problematic (see figure 3). Today I use a much more sophisticated testing method than a Lamotte or Hach test kit, I use a colormetric multiparameter spectrophotometer that is over 100X more precise and accuracte over wider ranges, self test, uses a blank and autocalibrates. This is a very user friendly device and is used to answer specific questions rather than monitoring a "routine" as a matter of practice for the average aquarist but it will not hurt the aquarist in doing so.
I truthfully do not know what levels of NO3 and PO4 (for example) cause problems for plants or induce algae in a fully planted tank. NO3 levels above 40ppm can cause fish health issues. PO4 at very high levels can influence alkalinity (KH) above 5ppm-10ppm.
Clearly these are far beyond the needs of plants and the range makes for a very large target to dose even if the aquarist is off by a factor of 2X.
Lighting is very expensive to measure correctly in an aquarium(I use a PAR meter that measures light in micromoles/m^2/sec) . It is one of the biggest unknown variables in keeping planted tanks, watts/gallon does not tell you much, but rough guides are fine if the aquarist maintain the CO2 and nutrient levels well. Dosing can be done using dosing pumps if the aquarist wishes, but it is relatively easy to do with a good routine. They can later tailor their routine to add “just enough” and further maximize their nutrient dosing to their individual tank’s needs. An important aspect of this method is the knowledge that excess nutrients do not cause algae blooms as so many authors in the past and many today still maintain without having tested this critically in aquariums with a healthy plant biomass. It is a welcomed relief knowing that “excess” phosphate, nitrate and iron do not cause algae blooms.
For many years this has been the assumption but it is incorrect. Ammonium (NH4+) at low levels have been the primary causative agent for algae blooms in terms of an "excess" nutrient. This is why a planted tank using CO2 with moderate to high lighting cannot have enough nitrogen supplied by adding progressively more and more fish to the tank without getting algae blooms. It does not take much ammonium to cause the bloom. If you add NO3 from KNO3 you will not get any algae bloom, if you add even 1/20th of the ammonium you will get a very intense algae bloom. This test can be repeated many times and ran again and again with the same result. Adding NO3 will not induce the bloom. See if you can prove this to yourself.
With the exception of NH4 and urea, higher levels of PO4 (phosphate), K+, potassium, and NO3 to large extent as well (to 20-30ppm or so) and Fe (iron) can be maintained without any negative effects even at extremely high light wattages (e.g. 5.5 w/gal at 30cm depth, using mirrored reflectors, U shaped power compact lamps-450 micromoles @ 8cm distance from the lights, most submersed aquatic plants fully saturate photosynthesis at 600micromoles/m^2/sec or so, at least the one's that have been tested at non limiting CO2 values, other species may have different levels).
The reason I chose this high light intensity was to reduce the time before an algae bloom would occur and prevent competition for light. This is similar to taking a "test drive" at high sppeed in a new vehicle. If algae was to occur due to higher nutrient levels, if would occur when the light, CO2 and nutrients were non limiting for both sets of variables. With less light, down to a point (Light compensation point, the LCP), we can assume less uptake and less issue maintaining a “stable range” of nutrients. It is much more difficult to tease apart the relationships when the rate of growth is slower (e.g. less light), it takes more time to note differences in plant growth and places less stress/growth rate on the system. It also reduces error since the uptake rates are high enough to get good test kit resolution whereas at 1.5-2.0w/gal with normal Fluorescent lights it takes much longer for 5 ppm of NO3 to be removed. Good test kits like Lamotte were used also to increase accuracy in the results. These test kits were tested against a series of known standards to confirm the accuracy. In this manner I could test the ideas with much more confidence. If I chose to test a non CO2 plant tank, this would have taken a very long time with very expensive test kits and methods. Additionally, many of the nutrients would be used up quickly before I had a chance to measure them.
Returning back to non CO2 planted tanks after gaining this knowledge at high light and CO2 enrichment allows some fairly good predictions/correlations of uptake rates for non CO2 planted tanks as well. The rate of uptake is reduced due to less light and less CO2. I generally use about 6 to 1 slower uptake rate ratio for non CO2 tanks but the fish loading can change this ratio. Basically the non CO2 tank grows 6-10x slower than a CO2 enriched tank.
This method is specific for CO2 enriched systems with higher light but works even better with lower light CO2 or SeaChem Excel dosing for carbon enriched tanks or salt water and other tanks needing a certain amount of nutrients. I suggest 30ppm of CO2, while a tank with 2 w/gal might be okay with 15-20ppm, many with power compact bulbs and reflectors need to have their CO2 levels higher, 20-30ppm range is optimal for the lighting period. This was found by adding more CO2 until there was no net gain in plant growth while keeping the nutrient and lighting levels consistent during the testing period. Research on three aquatic weeds showed that the plants will reach and carbon fixing maximum at around 30ppm of CO2 no matter what light intensity is used (Van et al 1976). The maximum CO2 level no matter what light set up you might have is about 30ppm for these three very fast growing weeds, which we can assume have higher CO2 needs/demand than slower growing aquarium plants subjected to less intense lighting than sunlight. While the needs of some plants might exceed some of these parameters, it’s very unlikely that this will occur and I’ve found no evidence to support otherwise having grown close to 300 species of submersed freshwater aquatic macrophytes. The CO2 level is enough to support non limiting growth, just like PO4, NO3 and traces. So in a sense, CO2 is over dosed since it's an easier target to hit and measure. Adding more will not harm plants and is only limited by fish health and O2 levels.
While many have discussed the merits of nutrients, fasr too many new people fall victim to low CO2,even the expert often gets caught trying to keep a good CO2 level in their tanks from time to time. No nutrient routine will perform well without good stable CO2 or Excel(Seachem).
Using tap water
Tap water is cheap and water changes take less time than the testing (salt water is the exception perhaps, salt mixes cost a fair amount money). Water changes also cost less than test kits/testing and are more fool proof method of estimating the nutrient levels in your planted tank when dealing with NO3, Fe and PO4. It's also simpler and requires less knowledge of chemistry and testing against known standards. Plants are most often starved of nutrients and inaccurate test kits are largely responsible. Many people feel tap is unsuitable for plants, this is simply not true. Old myths still abound claiming excess PO4 in tap water causes algae, this has clearly been shown by many hobbyist to be patently false. The tap water has nutrients in it, then you do not have to dose these nearly as much, this is actually a good thing! Why take something out and then add it back again?
Have hard water?
Great, you do not have to add any baking soda and GH builder to your tank. Adding enough GH to bring the levels to 3-5 GH degrees will address higher light tank needs over a week's time. You can use SeaChem Equilibrium for this or a mix of CaCl2 (or CaSO4 although it is not as easy to dissolve into water) and MgSO4 at a 4:1 ratio to increase GH. You can add this without knowing what your GH is by adding 1 degree's worth after a weekly water change (or slightly less with less frequent water changes)
Plants prefer soft water? Not so, neither myself or other experience aquarist have found plants that are soft water dependent, although there may be a few exceptions out perhaps 300 species, it is safe to say that plants prefer harder water and there is research to show this is true, (Bowes 1985), (T. Barr, C. Christianson observations of clear hard water springs in Florida, USA and in Brazil). A few plants, about 5 or 6 or so species do seem to prefer softer water, but this is due to KH, GH seems to have little bearing as long as there is enough Ca and Mg. So the GH can be dosed a little higher if in doubt or if you want to check to see if that is causing an issue or not.
KH on the other hand does seem to influence these specific plants(most are not affected) to about 5-6 degrees. There is really no limit on how low the KH can be for good plant health, but it can make CO2 measurements trickier. There is a way around that though. Still, any plant can be grown at a KH of 5 and a GH of 5-10, or less. This would not be considered "soft" water, actually it would be ideal. Thus unless you desire to grow a few eclectic species, there is no need for RO, nor DI, carbon filtration of the tap water, but doing so will do no harm to the plants as long as there is enough GH for the plants and KH to determine CO2.
Water changes: use Python like bucket less water change systems, or DIY garden hose systems that attach to a faucet for draining a filling. Large diameter drain hoses make quick work for large tanks. Dedicated plumbing also can make the water change very easy. If the tank is far away from the faucet, a longer hose is all that’s needed. Hard plumbed systems and automatic water changers are commonly detailed on the web.
The Problem
#1 Dosing.
This can be very tricky when dealing with many variables. Often the suggestion is "buy a test kit" and test to see what your nutrient levels are.
I suggested this almost ten years ago:
http://www.sfbaaps.com/reference/barr_02_01.shtml
This works well for CO2 (but folks should double check to be sure before proceeding on) and GH but the other nutrients like NO3, K, PO4, iron as a proxy for the traces are more problematic. Often times the poor aquarist chases one nutrient to the next and spends a small fortune and time as well carefully testing each week, or several times each week trying to figure out what is missing. Generally many never find what is wrong after doing all that.
95% of the time is was CO2 levels were too low and the issue had nothing to do with the nutrient dosing routine. Simply doing a large water change removes all the variables, and dosing known amounts back in to the tank of the nutrients effectively re sets the tank each week. Even if you are off by a little, you do not have to worry about running out since the levels I’ve suggested are for high light tanks and you know if the CO2 is in good shape there is no fear of algae from these levels of nutrients in the water column either. Knowing this allows great flexibility and a very simple method to keep a fairly constant level of any nutrients in your tank and no need to test. You can guess the doses for the reminder of the week and then repeat. Chuck Gadd's dosing calculator works well for the chemistry challenged and those wanting to know how much of what to add. See here: http://www.csd.net/~cgadd/aqua/art_plant_aquacalc.htm
There is no hard and fast rule here when dosing or doing 50% weekly water changes. This method can be applied to water changes once a month or once every two weeks, better more consistent results will be obtained when doing 50% weekly water changes, but a well run tank can go longer without a water change. The aquarist can note plant health and dose slightly less as they gain experience of their individual tank's needs. As they get a feel for the dosing they can tailor the tank's needs further.
This is an exampled for folks using 10ppm of NO3 dosed each week and assuming 0, 25, 50, 75% uptake by plants/bacteria. the maximum build up in this case is 2x the weekly dosing rate. This shows the range in a mathmatical model (thanks Gomer) so that while no test kit is needed by the EI user, a very accurate test has verified these curves and ranges and match well with observations, models and testing methods.
So this begins to get very close to stable nutrients level and much less merely "guess" work.
#2 Testing
This is huge issue for most folks. Test kits cost as much as a filter or much more in some cases. Some folks can afford nice Lamott/Hach kits, most cannot nor wish to invest 300$ in this. Cheaper kits are not offered for K. NO3 kits are very problematic and color reading scales are difficult to assess with cheaper kits. Some folks are color blind. Many folks don't ever want to test and/or feel there's no need to test. I could not get some hobbyist to ever test no matter what I told them to do! I fell into that group for many years. I did as well as I do today but I am much more consistent now and I also know why it works! I know the rates of uptake and have done a lot of testing since my bad old days. I also did large weekly water changes so if I messed up dosing, I always reset the tank each week. I have a relative simple methodology to side step much of the drudgery especially with testing iron and NO3. At issue here is the maintenance of the nutrient levels within a certain range. The focus will be on 2 groups, nitrate (NO3), phosphate (PO4), potassium (K), the so called macro nutrients and the trace elements represented by iron (Fe) as a proxy for the other trace elements that are included in trace nutrient mixes. There are a few specialized test kits and meters available for many of the trace metals and Boron, but virtually no hobbyist ever measures these. So everyone is guessing about the traces as it is, even the most ardent proponent of testing for dosing!
Using teaspoon (Dry powders) and milliliter measurements (liquid solutions) we can be very accurate.
Perhaps a better question is how close to a good range of nutrients do we have to be to have excellent plant growth and no algae?
Using an "estimative index" the accuracy can be as follows for teaspoons and liquids for the traces, note, further accuracy can be achieved by diluting grams of each of these nutrients into DI water and adding mls of a concentrated liquid into their tanks in place of dry powder, but thios does not gain the user much in terms of plant health and growth, which is the main reason to help improve a routine:
(+ or -) 5ppm of CO2 is fine in a 20-30ppm range.
(+ or -) 1ppm or so of NO3 is pretty reasonable.
(+ or -) 2ppm of K+ is pretty reasonable.
(+ or -) 0.2ppm of PO4 is pretty reasonable (?)
(+ or -) 0.1ppm of Fe is reasonable (?)
CO2 range 25-35ppm
NO3 range 5-30ppm
K+ range 10-30ppm
PO4 range 1.0-3.0 ppm
Fe 0.2-0.5ppm or higher (?)
GH range 3 degrees ~ 50ppm or higher
Note:
PO4 and Fe are two nutrients that are difficult to assess without first assessing the other nutrients. If the NO3, K, and CO2 are in good shape, you can add a fair amount of these within a wide range. I have added to almost 3ppm of PO4 consistently week after week. Plant's response is incredible.
Green spot algae has never been an issue when high PO4 levels are maintained even under high light with Anubias. Adding traces has been a focus for me lately. Many have stuck with the old standby of a residual of 0.1ppm of iron(namelt from the work done developing PMDD). Well what does this residual tell us? Does it tell us what is available to the plants? Is this enough? Do higher doses cause algae?
Setting up a test
I can tell from my own experiences that high levels of traces (Fe) have in no way contributed to any algae presence. I double checked the other nutrients before drawing a conclusion. Few hobbyists and it seems no aquarium companies bothered to look at it from this controlled perspective. In order for the aquarist to draw a conclusion about a nutrient, it must be isolated and you must test only for the dependent variable. This is relatively easy using the Estimative Index; essentially they are making a reference solution each week of the proper nutrient levels and guessing closely till they perform another water change. This gives the aquarist a powerful simple and easy to use tool/method to provide a more controlled environment without nearly as much work. At some point the plants will not take up any more traces. Same can be said for PO4. Adding more simply will not improve plant growth any further. Many plants will take up excess, often called “luxury uptake” of nutrients like PO4 and NO3. So it may not improve growth even if the plants are taking in these nutrients. We must be careful not to assume that uptake=growth/need.
This is where the top end of a range should be. No need to waste expensive trace nutrients. Aquarists that have had issues with algae prior may want to try adding the PO4 and then adding more traces in conjunction. This works well even at the very high light levels. If an algal bloom was to occur, it will express itself more rapid and intensely at higher light. I had been dosing large amounts of traces all along since my reference sometime ago had been Karl Schoeler's 0.7ppm recommendation and I felt like a little more might help if the tank was doing well as many recommendations seemed middle of the road. Karen Randall has suggested a number of aquarist in the past found levels of CO2 higher than the commonly suggested 10-15ppm of CO2 although few have come forward to suggest this recently. Although I had tested numerous times and tried to look for some correlation with the test kits for uptake, I became less focused on the testing aspect and came up with what I think is a better method for the traces. I still contend most aquarist under dose the traces a great deal. I was never scared of algae blooms due to in large part all the battles I’d done with algae in the past and then went on to study and induce algal cultures in marine and freshwater. Few hobbyists are willing to destroy their tanks with an algae bloom to figure out why algae are really there. That is what was required to figure out what causes algae and then this process must be repeated to make sure the results are not an isolated case and can be repeated by other researchers elsewhere. Often times, we only test after the algae is already there, often missing what really caused the algae to begin with. So knowing how to repeat the bloom and induce it, is a key role in understanding of the cause of the algae in our tanks.
The estimative part
Aquarists simply add a set amount of traces to a known volume of water (mls/day/liter of tank volume). If the tank has less plants, low light, this can/may be reduce in frequency but not dosage. A similar pattern can be done for the macro nutrients. In this manner you essentially are making a "reference solution" each time you dose and you assume a certain amount of uptake the other one or two times prior to making a large water change at week's end. If you have low plant density or have low light (two watts or less Normal output FL's) you can get by on once a week. By knowing what the tap water is comprised of and giving the water company a call to find out what the PO4, NO3, K, and Fe levels are, you can replace the water with water changes and use plain old chemistry or Chuck's calculator to figure out what you need for your nutrient levels without a test kit. Even if you are off a little that's okay (see above pluses and minuses). The water utility will have some variation but if you are close to the middle ranges it should still come out fairly close. So imagine a tank where you don't test except for CO2 (pH and KH) and only that once in a while. Everything grows well. No guessing. Sound good? The results certainly are. Tanks never seeing any algae are quite common, 10 years ago, this was not the case.
Aquarists have tried the substrate dosing only method for many years with hit and miss results. Eventually the substrate runs out of the nutrients, then the plants suffer. While you can either tear the tank down and start completely over each year or so, or re-enrich the tank, you generally are left with having to wait till something goes wrong before you do something about it rather than keeping a close level maintained like the water column. Some tanks with moderate/low light and good fish loads can support the plant’s needs without adding macro nutrients for extended periods but that is still dosing, just the rate is slow enough to maintain the plant needs for that lighting/CO2 level, but the algae are far from limited. Anyone with a bloom that has tried to water change the algae away knows that is not true. The other issue about folks that often do not add macro nutrients/traces etc, is many do large water changes. These folks often do not know what their tap water has in it. If it is rich in NO3 and PO4 like many regions of the USA and Europe, then each week they do a large water change, they are adding nutrients and CO2. People wondered why my plants did so well with the water changes I did each week and when they tested found high levels of PO4, I was adding KNO3 and lots of traces and high light and high trace dosing and had no algae and dramatic plant health and growth. Several methods suggest substrate fertilization in the start up phase followed after a period of a few months of slowly adding water column fertilizer. Any long term method eventually becomes a water column dosing method unless the substrate is re enriched or torn down and re fertilized. Substrate nutrient content is extremely difficult to measure while the water column is much easier to measure and dose consistently, providing a more stable nutrient level for the plants.
You can extend this method out to include all the other nutrients like traces and PO4 even KH and GH. You can try whatever you feel is "perfect" for plant growth and experiment around. Good sized weekly water changes are an excellent way to do this and avoid build up and any **dosing** errors or **testing** errors. Test Kits (good ones) are not cheap and many are too inconsistent or do not want to be bothered to use them. This method used KNO3, KH2PO4 and Trace mixes and you can use a variety of trace mixes to try out your own routines. KH2PO4 (Fleet or generic enemas can be substituted, these are sodium phosphate based) and KNO3 are very cheap and traces are relatively cheap unless you have a very large tank, there are cheap dry mix traces available as well. The good thing about this method is that the fertilizers are available the world over, cheap, consistently the same, not brand name aquarium products and thus much cheaper. When I suggest to Wu in Singapore to dose ¼ teaspoon, 1.67 grams of KNO3, he can dose the same thing I use here, he might not be able to get some brand I like here of some aquarium product. So this method can be used the world over, not just in the USA.
A Typical Tank
A typical routine for a high light tank with low fish load:
Volume 80 liters (20 gal high standard tank)
5.5 watts/ gal. - two 55watt 5000K/8800K lamps
CO2-25-30ppm (I turn my CO2 off at night)
Canister filter
Fluorite (any porous iron rich material will do) about 7-10cm depth
A Typical Dosing Routine
1/4 teaspoon of KNO3 2-3x a week (every other day)
1/16th teaspoon of KH2PO4 2-3x a week (every other day)
Traces added on off days as the macro nutrients, so 3-5x a week, 5mls each time.
SeaChem Equilibrium or GH BOOSTER 1 teaspoon after water change
See GH booster again, many overlook this part.
So the aquarist dose only 3 things really, KNO3, KH2PO4 on the day of the water change then every other day there after, traces of the off day till the next week rolls around. Do a 50-70% water change, dose the macro nutrients back, add the traces the following day and repeat. You can slowly back off this amount till you notice plant growth differences to tailor your individual tank’s need, but all you will do is waste some macros and traces by adding more than the plant needs. You should give each change in your routine about 3 weeks before making another change. This will take time but is worth the time spent. It will not cause algae unless you over look something, namely CO2 or under dosing KNO3 which both of these account for about 95% of all algae issues. If you focus on the plant’s needs, the algae will no longer grow. I hope this helps and ends much frustration for the aquatic gardener so then aquarist may focus on aquascaping and growing plants rather than asking how to kill algae. The aquarist does not have to stick with merely a weekly routine with the water changes or accept 50% as their volumes. This will level off the dosing at 2x the dosed amount so that nothing will ever be overdosed beyond 2x the target range.
The math behind this is as follows:
http://fins.actwin.com/aquatic-plan...1/msg00416.html
Example #1
Suppose you dose 10ppm of NO3 total to a tank per week. Assume you do a 50% weekly water change. If you do the math, you find out that:
If you assume that NONE of it is used up, you can build up a maximum of 20 PPM
If you assume that 25%of it is used up, you can build up a maximum of 16 PPM
If you assume that 50%of it is used up, you can build up a maximum of 13.3 PPM
If you assume that 75%of it is used up, you can build up a maximum of 11.4 PPM
The concentration will not be 15ppm with 25% weekly uptake because of the previous week’s build up if factored into the equation.
Typical model nutrient removal experiment graphical data of concentration versus time
  • Types of uptake experiments: Problem: cells become saturated w/time so uptake is underestimated at low concentrations. Uptake depends heavily on light, this unit is poorly measured in the aquarium hobby and presents challenges in the field for researchers due to changes over time, seasonal, monthly, daily, minute by minute, second by second (Clouds, sun flecks etc).
  • There is a distinction between uptake from the medium and assimilation into organic compounds, especially Nitrogen [NO3-] and [NH4+] and amino acids. This depends on the ability to store inorganic ions, the rate of the enzymatic steps and the cell needs.
  • Cells can adapt and acclimate to chronically low nutrient levels by surge uptake capacity (Vm)
  • 2 basic models: Monod model: based on external concentrations, which maybe below detection limits but still biologically relevant and the Droop Model which is based on internal concentrations which is often more important and easier to measure since the concentration is higher than the instanenous external concentration. External concentration is a scale problem as well: micro algae may perceive micro patches of nutrients in microliter volumes whereas we measure integrate typically in then milliliter ranges. Put another way, comparing a the elephant and mouse model, both are herbivores: but we are measuring only large scale plant mass(say trees), not the small patches of short lived herbaceous plants that can feed the mouse but if the elephant has to rely on solely, would starve. Some plants are better than others at this uptake also due to surface: volume ratios.
  • Myriophyllum has much high surface: volume ratio than Anubias, The surface area to volume ratio allows Myriophyllum to be a much better competitor for nutrients than Anubias in the water column, but the Anubias makes up for this by growing slower and can withstand lower light levels. Adding excess nutrients and CO2 allows both plants to grow well together without competition.
This is typical generalized model for growth and uptake of a variety of autotrophic organisms. Based on Figure 3 above, from a horticultural perspective, it is more productive to provide non limiting conditions (green box-good target range) for aquatic Macrophytes as the target concentration is much wider as well as higher associated growth rates. Maintaining a set static concentration continuously through time is difficult and impractical to most horticulturists, but a useable range is rather easy to accomplish. Aquatic macrophyte limiting can be useful when exploring individual species differences and responses, but this is hardly a good method for stable horticulture. Non limiting nutrient and light levels need to be quite high before inhibition occurs. These inhibitory levels are unknown for many nutrients as far as aquatic Macrophytes are concern and are generally bounded by toxic concentrations to fauna such as fish and invertebrates (see table 1 for more on the maximum ranges tested individually in isolation1). This range provides an enormous useable range that is relatively easy and simple to target to provide stable levels for horticulture. The limiting range is much narrower and more difficult to provide a stable range from a practical standpoint by not providing much error in dosing and loading rates. Since light typically drives uptake rates, lower intensity of light will provide for less error at low limiting nutrient levels as long as the light compensation point is still being met. Generally, lower light intensities near the LCP have a lower range when non limiting nutrients are provided as well. The study done by Tropica showed this with Ricca and Van et al (1986) showed this same result with three submerged aquatic Macrophytes. In both cases from a horticultural perspective, non limiting nutrient levels are superior with more robustness in stable culturing methods with lower light intensity.
The end result is dramatic macrophyte growth and low algae presence with a simple to use method that allows the aquarist a wide range of dosing routines and healthy growth.
While many books and articles will suggest otherwise, higher nutrients levels and relatively low light can provide dramatic growth. All you need to do is test and try it for yourself to see that this is the indeed the case. The theoretical suggestion for the support of their contentions does not follow, nor does the practical experimentation.
Once applied, EI can be very easy to do and cost very little. It is a simple procedure and basically only CO2 related issues affect the tank and plants, effectively ruling out all the nutrients other than CO2.
Additional References:
Bowes G. 1991. Growth in elevated CO2: photosynthetic responses mediated through rubisco. Plant, Cell and Environment, 14: 795-806 (invited review)
Madsen TV, Maberly SC, Bowes G. 1996. Photosynthetic acclimation of submersed angiosperms to CO2 and HCO3-. Aquatic Botany, 53: 15-30
Additional reading:
Canfield, D.E., Jr., K.A. Langeland, M.J. Maceina, W.T. Haller, J.V. Shireman, and J.R. Jones. 1983. Trophic state classification of lakes with aquatic macrophytes. Canadian Journal of Fisheries and Aquatic Sciences 40:1713-1718.
Canfield, D.E., Jr., J.V. Shireman, and J.R. Jones. 1984. Assessing the trophic status of lakes with aquatic macrophytes. pp. 446-451. Proceedings of the Third Annual Conference of the North American Lake Management Society. October. Knoxville, Tennessee. EPA 440/5-84-001.
Canfield, D.E. Jr., and M.V. Hoyer. 1988. Influence of nutrient enrichment and light availability on the abundance of aquatic macrophytes in Florida streams. Canadian Journal of Fisheries and Aquatic Sciences 45:1467-1472.
Canfield, D.E. Jr., E. Phlips, and C.M. Duarte. 1989. Factors influencing the abundance of blue-green algae in Florida lakes. Canadian Journal of Fisheries and Aquatic Sciences 46:1232-1237.
Agusti, S., C.M. Duarte, and D.E. Canfield Jr. 1990. Phytoplankton abundance in Florida lakes: Evidence for the frequent lack of nutrient limitation. Limnology and Oceanography 35:181-188
Bachmann, R. W., M. V. Hoyer, and D. E. Canfield Jr. 2000. Internal heterotrophy following the switch from macrophytes to algae in Lake Apopka, Florida. Hydrobiologia 418: 217-227.
Bachmann, R.W., M.V. Hoyer and D.E. Canfield, Jr. 2004. Aquatic plants and nutrients in Florida lakes. Aquatics: 26(3)4-11
Bachmann, R. W. 2001. The limiting factor concept: What stops growth? Lakeline 21(1):26-28.
Van, T. K., W. T. Haller and G. Bowes. 1976. Comparison of the photosynthetic characteristics of three submersed aquatic plants. Plant Physiol. 58:761-768.
I would like to thank Neil Frank, Karen Randall and especially Steve Dixon for their input over the years as well as Paul Sears and Kevin Conlin, Claus from Tropica, SFBAAPS folks, each added to the development and understanding of EI. It was team effort to address the many algae issues we had at the time.
Copyright Tom Barr 2005
1 Note: this is for individual inhibitory concentration level, not combinations or two or more
Aviel Livay
Junior Poster
Feb 20, 2005
13
Re: The Estimative Index of Dosing, or No Need for Test Kits
Tom,
Here's what bothers me with this method, hope you can help me.
In the first paragraph I am required to decide what's the plant maximal uptake rate.
Well I think in my tank it's 1 ppm no3 per day - that's because something is wrong, trust me I have enough light, CO2, po4, micros, younameit and this is the maximal uptake with an average of maybe 0.5 ppm no3 per day.
Now if I decide that this is my uptake rate then I start dosing 1 ppm per day. If I keep on doing this and my tank improves for some unknown reason (and there are *always* unknowns) then mid week I shall have 0 no3 and by thursday WC I shall already be infested with BGA.
If I decide that 3 ppm is more likely a maximal rate although my tank eats only 0.5 ppm per day. Then after 7 days I shall have 7 * (3-0.5) = 17.5 ppm. After WC Is hall have 8.75 ppm. And if I continue this math shows that I shall swing between 17.5 ppm after WC and 35 ppm just before next WC. So it this how I am supposed to grow my sensitive plants? For example doesn't Rotala Macrandra prefer low no3?
And if I set the uptake to 4-5 ppm then I shall have swings of 30-60 ppm. I tried it - @ 50 ppm no3 the k levels were ~40 ppm (I measured) and ludwigia sp. pantanal leaves curled drastically because apparently K won Ca.
I am not trying to criticize - on the contrary - I just want to better understand.
Thank you,
Aviel.
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
Correction, adding small amounts of NH4 is okay for some planted tanks, but likely should be done only if you are somewhat advanced.
Aviel Livay said:
Tom,
That assumption is based on the max rates..........we dose above the needs of the plants in all cases anyway.
So this level will provide enough nutriwents for any tank, regardless of light and low fish loads.........
It assumes that deficencies, not excess causes algae.
And you can prove this to yourself with most any nutrient.
So if you have excess, that's not an issue, a very high excess is merely wasteful, but does little if any harm and does not encourage algae.
Sure, that's fine.
No, my client's tank gets high NO3 and has all these plants as I do at home, plants look and grow well, I doubt you'll get 35ppm in your tank, 20ppm is about what many end up with.
Thank you,
Aviel.
I doubt you have 4-5ppm of uptake per day, I'm not quite sure waht your question is here.
I did 75ppm NO3 with KNO3 dosing, I had N pedicillata, I had Ammannia, as have many others, no issues.
We grow L panatal here, many folks do, it's available at the LFS here in Albany, no one has mentioned issues with it and K/Ca.
But we are not adding 50ppm.
I do not suggest adding that much KNO3 either.
See 5-20ppm or so ranges, 20-30ppm should not cause an issue for any plant.
I have soft weater and used soft water the last 3 times I investigated K/Ca issues, it's something else.
I've yet to see this occur in any plant species named. I add plenty of K+.
It might be mulitple things occuring, but it's not K+.
I use SeaChem EQ and add a fair amount, KNO3, KH2PO4........you get the picture.
Plenty of K+. No issues, soft water. Supposed plants that are susceptible....
I don't have a problem and I've not been able to find one...........so I also have little motivation to investigate something I cannot see..........
It's like the old issue with PO4 causing algae, how come I don't have that problem if this is true?
Is there some sort of need to add 50ppm of KNO3?
Take weekly measurements and substract the amount dosed from the water measurement. There is some due to denitrification. You can measure that amount due to denitrification by removing the plants for a week and then adding them back again after the test.
If you are micro managing and taking daily measurements, then the accuracy is not going to be as good, also do this many times, not just one of two weeks. Then try it with many plant species..........
Aviel Livay
Junior Poster
Feb 20, 2005
13
The fact that many end up with 20 ppm doesn't change my calculation showing minimum of 17.5ppm and maximum of 35 ppm. Do you agree with my calculations? do you understand that if I want to stick to the EI then this is what I shall get?????? Do you think it's fine to grow Eusteralis/Macrandra with these levels? Will it optimize their colors????
Aviel.
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
Aviel.
I see no promblem. The calculations seem fine, not sure what type of test kit you are using, or if you are measuring based on the dosing calculators, whether you are asumming uptake by the plants etc.
Even a healthy growing tank will not use more than 20-25ppm per week.
But adding "just enough" is not the point.
The EI can easily be adjusted if you chose to reduce the amount or have another target, I do not set things in stone or insist to add this much, I am clear about letting folks know that this is the assumed maximum amount a tank will need.
If you wish to back off and reduce it to 1/2 that amount of KNO3, be my guest.
I can grow ES/RM are less for sure.............but at higher light, I like more nutrients.
Adding more ppm of NO3 or PO4 etc, or K+ or GH poses little if any risk.
Even 12-15 years later, no one has shown these pose any risk and nor have specified the ppm ranges that suppsely cause issues, and even in the few rare cases where they do offer up the ppm's, other quickly mention their tanks and observations do not confirm their claim, rather, falsify it.
The next stage is "assumed risk", without any proof or evidence there is any. If folks do not know, there's no need to automatically assume there is or not. You have to test it and see. People cannot suggest critical ppm's, risk and a need for testing etc, and then not take the same advice and test the upper bounds. Hobbyists rarely bother, particularly if they have already assumed that less is better with respect to nutrients. They are not going to try and test the upper bounds, because they already assume it's bad and "closed that door" as a test option.
Assumption without testing or ignorance does not cut it as far as an argument.
So is adding more bad? No, there's no evidence of any risk, whether you have 10-20ppm vs 40ppm NO3 or K+, even PO4.
In both cases, the N, P, K are non limiting. The points where they become detrimental for plants HAVE to be higher than typical Hoagland's solution which tends to be 210-235ppm for N, 200ppm etc for K+, 50-55ppm for PO4 etc.
Those are the typical plant science non limiting nutrient solutions used to provide and non limiting upper range.
EI is about 1/5th this.
See Gerloff's paper in the next post. There's support for what I propose in Plant Science, this is not something I pulled out a hat and is pure speculation. I came to this independently, but it's interesting there's a similar range and ratio in Gerloff's paper.
At lower light, I'll use less, it's not needed at that level.
You can also do larger water changes as well.
Many ways to mitigate and adjust things.
But starting at a upper non limiting nutrient ranges gives you a REFERENCE.
No other method really does this for the water column.
Then you can reduce it down from there should you chose to.
Some waste is acceptable above the min non limiting amount, but there's no need to lard it on, adding 20ppm of PO4 is not needed when 3-5ppm will do and offers a wide broad range with plenty of dosing "wiggle room".
17-35ppm is about in the 20-25ppm range, a few ppm outside the range is not a big deal.
If the level falls to 10ppm or 5ppm, no big deal, we do and often forget to dose every so often.....................
So that higher levels helps over time when we forget to dose. Folks seldom over dose by dosing 2x a day etc, so this helps that issue.
A water change removes it back down. The water change routine is not set in stone either, you can do 30% 2x a week, 50% 3x a week, 75% once a week, 60% every 2 weeks etc. Whatever floats your boat.
I'd try to keep the NO3 down to some degree due to waste and simply not needing more than 2ppm of PO3, 25-30ppm of NO3. You gain nothing by adding more.
All these recommendations are for is helping folks get back on track. You certainly might need less(most do), but the excess is not going to hurt unless you really go to extremes.
I think the notion that the excessive amounts are somehow bad is not well founded in anyone's argument I've seen to date, ferts are very cheap, water changes fix any errors quickly.
From there, you can start looking at shrimp toxicity since they are about 1 order of magnitude more sensitive to nutrients.
I've been breeding shrimp for a few years now.........CRS, Fire and RCS........as well as fish and raising plenty of plants for sale.
My tanks offer a nice collection+ a decent scape+ are a working farm for plants/crops and livestock fish/shrimp.
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
Some folks have suggested the GH issue is well addressed, well, it does not matter a great deal as long as there is enough relative to NO3/PO4 etc.
Most folks have higher GH's, invariably someone mentions Mg++.
This is supplied in many trace mixes and plants need some, but not like many of the other nutrients. Most high Gh water alos has Mg, this is not 100% the case, but topping off with a 1 degree amount of SeaChem Eq or Ca/Cl2/MgSO4 will address most GH related potential issues so you can rule any of that out with one simple dosing after the water change.
Here are the links that support the ranges suggested and the evolution of where and who did what.
Here's several paper that detail the general concepts: some on plants alone, and then a few for algae and plants,
PMDD from Paul Seras and Kevin:
Control of Algae in Planted Aquaria
Note the low T12 lighting.
Also, Paul is careful not to suggest that the PO4 go to zero, or strongly limits plant growth. Some assume less = better, this is not true.
Also, you can find the infinite series dilution at the bottom, the same approach can be used for all nutrients, not just Fe.
Steve Dixon and myself started testing the hypothesis that Paul put forward in PMDD, and we showed it to be false and today PO4 is dosed in many routines.
The ppm's for EI are based off Gerloff, 1966 and critical concentrations, Liebig's law on the minimum.
http://www.new.aslo.org/lo/toc/vol_11/issue_4/0529.pdf
20-30ppm are the critical concentrations for aquatic plants.
See table 1 also, this is similar to the PMDD recipe.
The light in units of PAR is about 100 micromols/m^2/sec
So moderate light, not high or that low either.
PMDD ranges are more likely to be less for their light intensities used.
Liebig:
On the Origin of the Theory of Mineral Nutrition of Plants and the Law of the Minimum -- van der Ploeg et al. 63 (5): 1055 -- Soil Science Society of America Journal
As you can see, the credit is also given to another => Sprengel.
and Hoagland 1938(1933 for Gerloff's reference)
http://www.siu.edu/orda/igc/proceedings/01/larson.pdf
Some hornwort NO3 discussion
You can see hornwort removed about 100ppm in 10 days, about 10ppm per day. This is at full sun though.
Gerloff's test showed about 20-30ppm for NO3 to provide non limiting growth. This was grown at
The algae vs plant issue is well addressed in Bachmann et al, 2002:
http://fishweb.ifas.ufl.edu/Faculty Pubs/CanfieldPubs/macrophyte.pdf
and a more simple version of the article for the general public:
http://fishweb.ifas.ufl.edu/Faculty Pubs/CanfieldPubs/Aquatics2004LR.pdf
Vladimir Zhurov
Lifetime Members
32
London, ON
Tom,
Can you please show an equation used to produce graphs and final values in "Example #1".
Regards.
Vladimir.
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
It's just a simple log curve.
If you desire to know the math:
http://www.plantphysiol.org/cgi/reprint/54/4/564.pdf
The basic equation is in there.
This same shape is also present for light and for CO2.
You should note the light efficiency use is reduced, so light is WASTED, if there's a nutrient stress, or a CO2 stress.
You are going to waste something, CO2 is a high demand nutrient, so it's not wise to waste that, nutrients are easy and cheap, so a little over doing it for ferts and CO2 is wise.
People complain EI is wasteful for excess nutrients and water, but it's a lot cheaper than wasting electrical energy, often the largest expense for cost for many aquariums.
Tropica's article also argues for high light use efficiency and good CO2/nutrients(non limiting):
http://www.tropica.com/article.asp?type=aquaristic&id=142
As someone who's researched plant science a significant amount, as well as someone who is a manager of a large Horticulture outfit in Europe, a pair of sharp researchers/professors who are well published, we seem to be in total agreement. It's the hobbyist that seem to have the issues and need the convincing :gw
Some examples of EI dosed tanks:
bobby269
Junior Poster
Sep 1, 2005
10
I odered the three chemical from Greg and looking forward to using your method.
I have a new bottle of Tmg, can that be used. My label got wet in shipment and can't be read. Is instead of what. It's a small bottle when its finished I
will completely use your system.
My KH is 11 and my Gh is 17.Should I still use Greg's equilibrium?
Thanks.
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
You likely have no need for any GH, but you can add a little MgSO4, epsom salt if you wish once a week after a water change.
Unlikely you need it.
TMG will work fine and was what I orginally used and since have gone back to it.
Some more of my EI dosed personal tanks.
Note the fish health, plant health etc, color, lack of stunted tips and other thing that are often claimed about over dosing, or EI etc.
If those are the only factors causing issues, why are they not present?
They are not the root causes then............
Ah_ZhaN
Junior Poster
Nov 1, 2006
2
Hi Tom, I caculate fert dosage by the mean of fertilator.
http://www.aquaticplantcentral.com/f...fertilator.php
The teaspoon used is a 5ml spoon, those meant for medicine consumption.
However, I had difficulty achieving 20ppm NO3, 2 ppm PO4 and 20ppm K per dosage.
My tank volume is 25.5 litres(6.375gallon) and lighting is 3.6WPG(US)
My calculated results from fertilator are :
A) 1/8 tsp KNO3 and 1/32 tsp KH2PO4
NO3 = 15.63ppm
PO4 = 4.79ppm (too high?)
K = 11.83ppm
B) 1/4 tsp KNO3 and 1/64 tsp KH2PO4
NO3 = 31.27ppm
PO4 = 2.39ppm
K = 20.7ppm
Should I adopt the dosage from A) or from B) ?? If not, how much tsp of KNO3 and KH2PO4 should I dose to achieve the best results for EI.
Thanks you very much, Tom.
zhan
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
With that lighting and with mainly stem plants, and thicker layout, likely the richer rotuine.
You have a tiny tank so adding dry ferts, say 4 week's worth into a 1 liter bottle then dividing that by 28 days in 4 weeks = 35 mls per day.
Dose the traces at 1ml per day of standard liquid commercial trace mix such as Tropica or SeaChem.
This is more practical when dosing smaller tanks than teaspoons.
If you have lots of fish etc, less plant biomass, eg all Gloss etc, probable the first choice.
These dosing suggestions are simply target approximations, there's simply no need to too worried about precision, main thing is a consistent habit and good CO2.
That is FAR more important.
Fishgovno
Junior Poster
Nov 2, 2006
12
Winterpig,Manitoba/Canada
Sorry but this a 2 part question:
1-What is a good GH for multi type planted tank?
2-Where do I find a proper dosing guide for the EI method?
The reason I ask is if I use chuck's planted page his fert calculator is missing the other various chemicals that can be used and if I use the APD fertilator it seems more leaning towards the PPS method and also seems like some of the numbers are not the same as Chuck's site.
The other issue is when mixing trace mix with 500ml ro water how many ML of trace mix do you use for a 100G tank (every second day)?
If possible please give example for EI method on a 100G tank
Using KNO3,fleet enema and CSM+B also adding magnesium (epson salt) and calcium chloride.
Thank you.
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
vafd;3601 said:
Tom,
Regards.
Vladimir.
For these curves, they are merely models, hand drawn, you'll note there are no units due to this fact:cool:
But if you want an equation, most graphical modeling pages will have them.
It's easier and addresses the topic here better if I leave that part out, it takes less time for me to draw a curve.
I think in terms of a graph, in pictures etc generally anyways, then go after the math and chemistry etc.
Here's some model graphs that show why the target effective ranges of nutrients are so large and easy to hit for hobbyists:
The 90% yield zone is the largest zone to hit as far as nutrient % in the plant tissue and also in the water column/soil.
These are basic to understanding anything in growth and mineral nutrition of plants.
Aquarist and farmers alike, look at ways to improve growth as much as they can.
This gives a more fine tuned example of this same curve. Moderate deficiency is not bad per se, it will reduce rates of growth, some find that management better, but since we also control light, and electrical cost are the largest expenditures, reducing light would be easier and simpler, not to mention cheap to manage than nutrients. This trade off with light, unlike nutrients/CO2, is much better because it also reduces the rates of algae growth as well, limiting nutrients to control plant growth does not affect algae, they are never limited in planted tanks.
Many have long assumed that there is a direct relationship between low nutrients and algae.
This is not supported in the research however, refer to Bachmann et al, 2002 for further discussion.
Experimentally, we can and have shown algae free tanks at high non limiting nutrients, see the examples here and elsewhere on the web etc.
So on both counts, this hypothesis has been shown to be false.
So why do some have less algae issues when they limit nutrients? CO2 plays a dominate role. Limiting one nutrient affects the uptake and demand of the other nutrients, CO2 included.
This goes back to Liebig's law of the minimum. Unlike terrestrial plants, aquatics are easily limited by CO2. So that is a very strongly limiting nutrient. If the other nutrients are non limiting, except for CO2, then algae often results, particularly when the light is higher. If the CO2 is also non limiting, then you have good results like the pictures here. So the hypohtesis often suggested that lower nutrients is better for algae, really does not address the real reason why the algae bloom occurs nor considers the test independently. If it was truly the case, and the test was independent of all other factors, all EI dosed tanks shoud have algae.
However, clearly, that is not the case.
So they have some other issue occurring, likely CO2.
When they also use high light + limiting nutrients, this situation is even more problematic.
This skews the balance strongly towards maintaining the non limiting CO2 demand indirectly through limiting the plant's demand for CO2 with a nutrient instead of light.
This can be done, there's no doubt about that, but this system is still not limiting algae directly, it's simply modifying the plant's demand for CO2 instead.
It also allows higher light, but that energy is wasted and if the nutrients creep up, and the CO2 is not adjusted, then algae appears, stunted tips etc which is common with CO2 limitation(this is seen in natural systems very often).
If the goal is about using "less", running things more efficiently, fewer water changes, less stress to the fish, then lower light will give the best stability. Light needs little management after all, common sense quickly lets the aquarist realize that. Likewise, there are several reduced versions of EI for non CO2 approaches, lower light and Excel dosing. Then you have less light(less algae/cost)+ less CO2 demand(easier/less algae as a result) and less nutrient demand(so you can maintain lower levels easier) and get by with fewer water changes, and if something does go wrong, it's much easier to correct things and you have more time before you have to fix the issue.
This is general advice, independent of any dosing method.
Dosing methods do not address light and CO2, and aquarist often over look these.
In doing so, they often set themselves up for problems and lots of work.
Plant growth starts with light=> then CO2=> lastly with nutrients.
If you follow this routine, it will help a great deal.
While many claim that more nutrients = bad on the web, rarely do we see much in the way of more light = bad. Which is ironic.
Neither case is bad and there are successful cases of each. Where the problem is, is in how they think the results are caused by.
If you lose sight of how a plant grows, or assume algae are actually limited by your dosing routine, then folks get into trouble.
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
NO3 = 15.63ppm
K = 11.83ppm
NO3 = 31.27ppm
PO4 = 2.39ppm
K = 20.7ppm
zhan
I'm not sure where you get these figures, are they from the same calculator?
Seems odd, but when you get down to smaller units of measure, eg 1/32nd of teaspoon, a lot of error can be introduced.
But if you look at the ranges the dosing produces, 15-30 for NO3, 2-4 for PO4, K+ 10-20ppm, not bad, it's a range, not an absolute measure, none of our test kits generally can achieve that much precision anyway.
If you also add the GH booster suggestions in this, then you will have a higher range of K+, about another 10-20ppm.
I'd general say dose 10 ppm of NO3 and about 1-1.5 ppm of PO4 per dose.
5mls or so of TMG etc.
3-4x a week if very high light, high light 2-3x a week, low light 2x week.
Same amount , just less frequent.
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
Thank you.
See our nutri cal here, it's a dowloadable version and has some nice features.
Chuck's page is quite old at this point in time, but it was the first one, I've never done one, I do things the old school way:)
I did not have a cal to do it, so I still do chem that way unless I have lots of data to plug and chug.
If you really do balance the nutrients effectively with a test kit, let's assume you do and can, then you are left with the focus on CO2. EI isolates CO2 very effectively as the main variable. Someone doing the a test kit and dosing balance method effectively will also achieve a similar thing. I make water changes easy as pie for myself(pythons, hard plumb drain/fills/automated solenoid water change systems etc), it saves me a lot of time and allows me more control. Amano does the same types of things. Point is, it' is a trade off there. One method(water changes vs a test kit) is not better than the other. Most hobbyists do a little of both. They want to check to make sure, rather than just blindly do EI and have "faith" it works. I suggest this approach also, and then modify to suit your target goal ppm's. EI was not written in stone.
Fish loading has much less influence when you do large water changes each week. Trace metal build up also is reduced via water change export.
Water changes also add CO2 and harass algae very effectively.
Some folks think the same old thing is something new and a few are tired of doing the same old thing, so it has appeal. Personally I am tired of using test kits, I like to garden and that is why I got into this hobby, to do just that, not micro manage my tank ad nauesum and play with test kits. I have done enough testing of soil and water for one lifetime already:)
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
Thank you.
I like a GH of 3-9.
If you have soft water, 2-3 is fine.
I tend to add about 1-2 degrees extra in most any tap water.
There's a few articles on EI that show the list of dosing examples, you can scale them up.
For a 100 gal tank with good CO2, decent lighting:
I'd add:
GH booster, 2 degrees worth after a 50-70% weekly water change
Dose 3x a week depending on lighting:
1 teaspoon KNO3
1/4 teaspoon KH2PO4 maybe a tad less
Traces, I'd add about 20 mls, I'd use Tropica master grow personally in place of the CMS
Greg will be selling a new dry mix fert this summer after I'm done testing it.
It combines a few things that are best from TMG and Flourish and adds a few other things as well that are lacking in both products.
The ratios of nutrients in the trace are based on dry weight ratios from about 30 aquatic plant species. I'm not aware if anyone has ever done an exhaustive study on that issue, I know I have writing about every essential element.
It'll be about 50$ lb but will make 50 liter's worth, vs TMG at 69.99$ plus shipping for 8-10lb of water vs the 1 lb shipping cost.
So it's about 10-20X cheaper than either the SeaChem or TMG brands and is more effective over the typical KH values encountered in the hobby.
Founder
Staff member
Administrator
Jan 23, 2005
18,699
786
113
Here's some further background on the general method, and why.
I think many are looking at growing aquatic plants with algae fear, fish toxicity, general bias from the hobby, rather than from a basic plant growth and science perspective.
Some more general concepts are from the salient research:
smik
Junior Poster
Apr 3, 2009
2
Hi Tom.
Why when there is uptake rates 0,2-0,6 ppm PO4 / 24 hours it is 1.4 -4.2 ppm a week. The EI is added to the tank 4ppm PO4 3 times a week. It is 12 ppm. The smaller dose was not sufficient to cover the consumption of plants?
I am sorry for my english I am use google translator. :)
nipat
Guru Class Expert
May 23, 2009
665
Tom's PO4 range is 1-3 PPM per week. He suggested a member in this thread to dose 1-1.5 PPM
of PO4 per dose.
And let's look at this instruction (for a 20 gallon tank):
1/16th-1/32nd teaspoon of KH2PO4 3-4x a week (every other day)
1/16 TSP = 0.3 gram
Adding 0.3 gram of KH2PO4 to a 20 g tank = 2.77 PPM of PO4
It will be lower by half if you choose 1/32 TSP.
Status
Not open for further replies.
