CO2 in Nature.
  • CO2 in Nature.
    Hello all!
    Tom has linked this Tropica Aquarium Plants article many times, to many various people:
    http://www.tropica.com/advising/tech...and-light.aspx
    It's a great article, but I have a question about one part of it.
    One of the paragraphs starts of like so:
    In nature, the concentration of CO2 is often larger in water than in air
    Is this true? Is the C02 concentration in natural lakes and streams really much higher than air? If so, how high is it? Is having say 30ppm of CO2 an environment you would readily see in nature?
    I know that in my aquarium if I don't inject CO2 the plants use up what's available to them very quickly,.. I'm sure that nature would be the same way if nothing were adding it back, so where is all this CO2 coming from?
    Thanks!
    James
    Aquariums Are Not "Natural"
    Hi James,
    I recall reading about lakes in Florida with CO2 in the range of 300-800ppm.
    I would think these waters so acidic that most critters and probably, plants would be hard pressed to survive.
    The answer is I am sure there are places that maintain 30ppm CO2, I just cannot tell you where.
    Almost ant place the water comes through limestone and hasn't been degassed by running through rapid or falls would be good places to start looking.
    Many river and lake beds produce CO2 in introduce it to the water column much as deep sand beds as substrates in aquariums.
    I have been repeatedly told that over 30-ppm the plants do not really benefit. My always unscientific observations suggest otherwise.
    Anyway I will let the Gurus handle the this.
      as biollante says alot of the CO2 in natural enviroments comes from the break down of biomatter in the river/lake beds.
      It is this reason that real soil is best to use in low tech planted aquariums as this releases CO2 into the water inplace of pressurised CO2.
      Oh oh oh... Just realised this is my first post on here lol. Sometimes you forget which forums you've posted on and which you just hang about!
        Welcome to the board Chris!
        Your right,.. aquariums are not "Natural", however I always had assumed that by injecting CO2 we were creating a very artificial environment for our plants to grow in. The idea that CO2 is so abundant in natural systems is new to me,.. and if that's true it totally changes the whole way I view CO2 injection. I've always wondered how the plants in lakes did it,.. if we needed the big tank of CO2 to keep them happy,.. well! If C02 in the lake/stream/river the plants and fish come from is abundant, then I'll I'm doing is creating a more natural environment for my creatures. I like the idea of that much better than the thought that I'm somehow putting the whole thing on "Life support".
        Know what I mean?
        Whiskey
          Know What ya Mean
          Hi Chris, James,
          Welcome Chris posting is okay!
          I prefer to think of our aquariums as systems, I think many problems people face are due to thinking of our little container gardens as being “nature in a bottle.” :gw
            Originally posted by Whiskey View Post
            Hello all!
            Thanks!
            James
            Yes, it is true. Depends on when you take the reading and how.
            Tom barr
              See several threads I've posted here about CO2 in natural systems, one VERY recently.
              These all have some very common themes.
              Natural sediments are good for lakes and other systems as a source of CO2..........however, for out tanks, they contribute a VERY limiting rate step, it's called aerobic respiration.
              Breath.........ahhh........see? You are doing it right now!!!
              Since many assume this is a big deal, try blowing all that "hot air" into the tank.
              See any difference? Change in Co2? How can add much CO2 without breaking down reduced carbon using O2??? The O2 has to come from somewhere right??? This works out well in a large lake with few plants, but not in a smaller tank. Some is used from this source, but much less than many seem to assume.
              So to get a residual for 6-8 hours per day at say 4ppm of CO2, not much.......we'd need to consume 4ppm of O2. So now you go from 7ppm of O2, down to 3 or less..and you have fish and less flow???
              This assumes that 7ppm O2 can be added back as fast it is used up to maintain 3ppm of O2.
              Ideally you'd have fast flowing high rates or aeration if this where really the case.
              But there's less evidence that helps.
                Oops,... I posted asking for elaboration while you were posting your post.
                I'm confused about what your saying - but I'll come back to ask questions once I look up the other natural CO2 threads you mentioned,.. I might better understand this post after I read those
                Whiskey
                  Interesting stuff, a good question Whisky.
                  In some places plants can also supplement their CO2 requirements via aerial growth (i.e. plant sticking up out of the water)...correct?
                    Hello Tom,
                    Could you do me a favor and tell me what the title of the threads your refrencing here are? I tried searching, but I'm not exactally sure what I'm looking for, and nothing jumped out at me in the search results. I want to better understand where your coming from, without having to waste everyone's time asking the same questions that have already been recently answered
                    Thanks for the help!
                    James
                      Yeah! Lilly pads, or duckweed jump immeditally to mind - these are perfect additions to non-co2 tanks, and do wonders on making sure algae is kept at bay.
                      Whiskey
                        Hello Tom,
                        James
                        Not Tom but I think this is a good
                        answer from him about this topic.
                        http://fins.actwin.com/aquatic-plant.../msg00327.html
                        The one he referred to is probably a trip that he got lost.
                        http://www.barrreport.com/showthread...-plant-nirvana
                          I don´t post here much....
                          But I wish to share pictures of an amazing place here in Brazil, named Bonito (translation: Beautyfull - yep, it´s the name of the city) which I found at http://www.aquamazon.com.br There we´re allowed to dive amongst astonishing places, almost feeling inside an aquarium.
                          http://www.aquamazon.com.br/?area=ex...es_baia_bonita
                          http://www.aquamazon.com.br/?area=ex...s_rio_da_prata
                          http://www.aquamazon.com.br/?area=expedicoes_rio_sucuri
                          There we have:
                          KH- 7
                          GH- 11
                          pH- 7.2
                          CO2- 13 ppm
                          PO4- <0.01
                          FE++ 0 ppm
                          Temperature 22°C
                          just a Bit:
                          Echinodorus macrophyllus carpet
                          Potamogeton illinoensis and some fish Brycon microlepis
                          Prochilodus lineatus swiming and algae (even there)
                          For photos and description (portuguese) follow the links.
                            Nice pics!!
                            I wonder what the water composition is here, including CO2...
                              That's awesome!!! Thanks for bringing us those pics
                              Do you know where all the Co2 comes from?
                              Thanks!
                              James
