Hello fellow lovers of tiny wet plants. I've done a ton of reading and tried to follow most of the directions given by you experts on the DSM with HC, but after almost 4 months I'm finally reaching out for help. I just can not get my HC to grow healthy.
I have a 20 gallon tall, using a 24"-36" Marineland Aquatic Plant LED (the longer one with lights to the edges) which is outputting about 120 PAR at the substrate surface at center line across length (I checked with my friend's PAR meter) and have it going for 10-12 hrs. I've used only Poland Spring water as the tap water here is terrible. Temp in the room is consistent at around 75f. I am using some ADA Aqua Soil Amazonia II that I bought a few years ago and has just been sitting in a closet until 4 months ago, it has been dry the entire time. My friend and I bought our HC from the same place online and started our tanks on the same night. His is now a complete carpet, very lush and looks amazing. As you can see from the pictures I'm attaching mine looks like a barren wasteland of poo. Help!
When I first started I had an issue with fungus. I sprayed in spots with a gentle solution of peroxide and water, 1:4 of 3% peroxide. And also pulled out the clumps that were being decimated. After that initial fungal attack I was fungus free after a week or two of battling it. I then gently flushed the substrate, pouring water in and siphoning it out from below the substrate to get rid of most of the peroxide that might have been left, at least that was my hope. Also the tank has never dried out, is covered with plastic wrap and I spritz often. Water is always just beneath the substrate surface.
But look at it, it's terrible! What's odd is it looks to me like anywhere the HC touches the substrate, it dies. But the higher leaves not touching look extremely healthy. If one of the shoots gets too tall and falls over both it's base and the tip which is now touching the substrate then go brown. Is my substrate poisoned? Did I perhaps go overboard with the peroxide? I've read a few people had issues with the Amazonia II, could that be it? In the shot glass you see in the wide shot I put a bit of extra Amazonia II and a couple of the plants as a test, the substrate in the shot glass has had no peroxide, but even those plants have gone brown at their bases. Have any of you seen this before? Advice?
Thanks a ton in advance for your time.
View attachment 5007View attachment 5008View attachment 5006
