yellow pogostemon helferi
  • yellow pogostemon helferi
    hi!
    just a quick question.
    Since the discussion: low light is better!! started, I joined the crowd and lowered my lights as well to 100 umol directly at the surface (and 50 umol at the substrate)
    However, the plants became very green. therefore I included twice a day a light peak of one hour (250 umol at the surface). plants have now a very nice colour. (happy)
    The problem is that I also cut back on the traces both iron and TMG, which resulted in yellow new growth of blyxa japonica and pogostemon helferi when dosed 5 ml TMG per day in my 90 gallon tank (which was very lean, I know)
    the addition of 7.5 ml flourish iron (0.2 mg Fe/l/day) fixed the blyxa within a week. however, the helferi remained yellow (both the leave and the veins).
    Then I increased 3 days ago the TMG dosis to 7.5 ml per day. no result yet...
    So: it must be an iron or trace deficiency. but which? what would be your thoughts?
    and if I don't see improvement the next couple of days, what would you do?
    greets,
    yme
    Pogostemon helferi is prown to color white(ish) when there is an iron deficiency.. Maybe you can try to dose your iron directly on the pogostemon (using a seringe) to see if that is the case?
    p.s. So lowering the lights + 1 hour peak worked for you in regards of plant colors (e.g. reddishness or what?)
      Why don't just double the traces and Fe so you can rule them out?
      How much macros do you dose?
        2x 1 hour peak
        yup, just the colour of the plants. instead of plain green, they now have a nice orange colour etc.
        I know . but they are not whitish. just yellow/very light green. and in contrast to what you see on the www: the veins are also yellow/light green.
        I am a bit scared for OD-ing traces. but I could give it a try... (low light, not much traces necessary)
        NO3: 30 mg/l (1 mg/l/day)
        PO4: 1 mg/l (0,3 mg/l/day)
        K: 20-30 mg/l (measured)
        Ca: 30 mg/l (calculated)
        Mg: 6 mg/l (calculated)
        thanks!
        yme
          Hi yme,
          I'm confused. Does this mean you are only dosing 1/16 tsp KNO3/day?
          FWIW, even though EI doses were determined using high light with good CO2, I do not understand why the drop off in plant growth requirements would be that great as long as you are adding CO2.
          <edit>
          I have always admired your "smarts" when it comes to this hobby. I have to wonder if you are over thinking this. I add 5ppm NO3 and 1ppm PO4 daily and have not had any problems to speak of. i am not familiar with their product but TMG doses of 7.5 ml per day also seams low. Please feel free to straiten me out.
            the concentration of NO3 in the tank is around 30 mg/l. (using a reference solution)
            calculating teaspoons to mg/l... (ah... Wet's EI calculator is great!!!)
            according to the calculator I add a little bit less than 2/16 tsp per 90 gallon per day in order to increase the NO3 level by 1 ppm.
            And since I don't have many fish (just a 5 flagfish that I don't feed, a SAE and some oto's) the NO3 consumption is rather low. which was also more or less the reason why I used less traces in the first place.
            greets,
            yme
              I wonder were the extra nitrate is coming from then?
              You can always try dosing something closer to the recommended EI. If that helps after a few weeks, slowly reduce the levels until you see a change in the plants.
              Short film about a man with an irrational fear.
                owh sorry.... I now see the problem!
                after the weekly 50% water change, I add all the macro's back to the desired level.
                greets,
                yme
